- 6,839
- 652
- 113
- Stratford/Connecticut
It folds out and goes past straight. If you push on the cab it’s as locked as it gets. If your pivot is stuck then it won’t work right.
This is all the further mine goes up as well, and my hydraulics are working fine. I believe the cab weight is over center at this point since the cab will not go down on it’s own until it lowered quite a bit from this point.I have seen the whole oblong assembly installed backwards. View attachment 754405You can see bottom right of the pic the lock arm is fully open.
