Results 1 to 8 of 8
Thread: Lmtv bed stakes
  1. #1
    Corporal
    Join Date
    Feb 2012
    Pa
    Posts
    44
    Default Lmtv bed stakes
    Still trying to find a pair of center side bed stakes for a 1078.
  2. #2
    4 Star General tobyS's Avatar
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,533
    1,745
    Default
    Are you interested in some made out of steel? I could use mine as a pattern, but don't want to give up the ones with my bed. I'll go check size to see if a standard size tube will work.
    Attached Images Attached Images
  3. #3
    Corporal
    Join Date
    Feb 2012
    Pa
    Posts
    44
    Default
    That may be the route I have to go. I was hoping for originals but they seem to be hard to find.
  4. #4
    4 Star General wheelspinner's Avatar
    Join Date
    Oct 2012
    North Carolina - FINALLY !
    Posts
    2,901
    1,476
    Default
    Let me check. I might have some available
    MSgt, USAF (Ret)
    "Be a person you would be proud to know"
    1985 M1009 CUCV; 1991 Ford ME350A1; 1990 BMY M923A2; 1988 M1038 ; 1988 M998 (SOLD) ; 1994 M1078; 1995 M1088 (2 Parted Out); 1995 M1083; 1985 M35A2C-85K274 (SOLD)
    MEP803a; MEP802A; This space Reserved
    For best results, try not to do anything stupid.
    MVPA #29740
    CANCER SUCKS, and that's all I got to say about that.
  5. #5
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,533
    1,745
    Default
    Wow...they are not standard tube size (of course). I measure 3 1/4" x 1 7/8" x around 3/16" aluminum. I have no idea where to get that raw material size.
    I can see using a 2" x 3"x 1/4" wall and mill 1/16" off of each side to fit the pocket hole, then add 1/8" flat to each side. And I would close the end off, so debris doesn't go down inside it.
    Do you need all the interior holes for the top canopy frame (or whatever they are there for) or only the hole for the door slider to hold the sides up?
  6. #6
    Corporal
    Join Date
    Feb 2012
    Pa
    Posts
    44
    Default
    Quote Originally Posted by wheelspinner View Post
    that would be great, found a few places parting out lmtvís but all want to sell the bed whole.
    Quote Originally Posted by tobyS View Post
    i donít intend on having a canopy, or even troop seats for that matter. Just basically something to hold the door sides up. I have a plate of 1/8 and my buddy said he would help me make them if needed.
    That at being said, there is a m1082 up for auction near me, which would help me on a few things with this truck. But thatís a long shot.
  7. #7
    Join Date
    May 2013
    Rochester, Indiana
    Posts
    3,533
    1,745
    Default
    Of course if wheelspinnner come through, that would be easy. Freight should not be too bad for aluminum.
    2x3x1/4" is a common steel size. It won't be too difficult with your friends mill.
    A wood member (painted green of course) would work too, for a while. Coming up with the oddball size would be easier in wood.
  8. #8
    4 Star General Steel Soldiers Vendor Suprman's Avatar
    Join Date
    Feb 2013
    Stratford/Connecticut
    Posts
    6,229
    19
    Default
    I should have some
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
