Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: Lost CTIS and all air driven stuff ?
  1. #11
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    8,491
    Thanks
    5,770
    Default
    Quote Originally Posted by 1951M1078 View Post
    The hole dam thing is one big "Question mark ". The "?" is more a ,what the **** is going on for me.
    Dryer is the new style and new about a year ago. Maybe 40 miles on it. The pop off valve was working right up to draining the three tanks.
    Question . What turns on the air compressor ? I thought it was the lack of a air pressure and at the limit valve. (may not have the name right) Could this control be stuck in the pump off position ?
    As for the power steering,I will need to try it. It did up to being parked.
    When the wet tank had air I could not get air flow from the big or little line. But it did leak ahead of the control valve as I was getting ready to remove it to take a closer look. That is when I drained the tank. This is also the point when I fired up the truck to see about air flow and got nothing.
    And I still need to know what "TM" to use. Please.
    https://www.steelsoldiers.com/upload...0-365-20-2.pdf
  2. The Following User Says Thank You to porkysplace For This Useful Post:
    1951M1078 (01-31-2019)
  3. #12
    2 Star General 1951M1078's Avatar
    Join Date
    Apr 2015
    Glendale,AZ
    Posts
    794
    Thanks
    433
    Default
    That is where I'm headed. Bet their would be less problems if I was using it as a daily driver.
    1960 #53 M151 (sold)
    1996 M1078 (LMTV)
    2007 4 Door JK
  4. #13
    Join Date
    Apr 2015
    Glendale,AZ
    Posts
    794
    Thanks
    433
    Default
    Thanks for the help with the TM's. Have them all down loaded but some one needs to make a manual for the manuals. LOL
    1996 M1078 (LMTV)
    2007 4 Door JK
  5. #14
    Join Date
    Apr 2009
    mid- michigan
    Posts
    8,491
    Thanks
    5,770
    Default
    That's in the TM section also.
    How to use/read Technical Manuals
  6. The Following 2 Users Say Thank You to porkysplace For This Useful Post:
    1951M1078 (01-31-2019), SCSG-G4 (02-05-2019)
  7. #15
    Join Date
    Apr 2015
    Glendale,AZ
    Posts
    794
    Thanks
    433
    Default
    I think I need more a "Manuals for Dummy's "
    1996 M1078 (LMTV)
    2007 4 Door JK
  8. #16
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,213
    Thanks
    105
    Default
    rig up a air gauge to the rear of the compressor first.. IF you cant hear your compressor knocking then smack the governor with a ballpen hammer. You should be able to hear it knocking to build air.
    Different vehicle type but the same idea and diagnostics.
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT3B turbo, Intercooled, #15 button, Dual fuel Line setup - MRAP Aluminum Radiator - 8" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    83' M923A1
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  9. The Following 3 Users Say Thank You to simp5782 For This Useful Post:
    1951M1078 (01-31-2019), coachgeo (01-31-2019), SCSG-G4 (02-05-2019)
  10. #17
    Join Date
    Apr 2015
    Glendale,AZ
    Posts
    794
    Thanks
    433
    Default
    What lub can be used on the unload-er to help with the sticking ?
    1996 M1078 (LMTV)
    2007 4 Door JK
  11. #18
    4 Star General Steel Soldiers Vendor Suprman's Avatar
    Join Date
    Feb 2013
    Stratford/Connecticut
    Posts
    6,229
    Thanks
    19
    Default
    The lube turns into hard pieces and gets stuck in places. I would start with seeing if there is air going from the compressor to the air dryer. Small steps.
  12. The Following 2 Users Say Thank You to Suprman For This Useful Post:
  13. #19
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,213
    Thanks
    105
    Default
    Spraying stuff in the unloader will just cause it to fail. Member Elijah learned that the hard way
    83' M923A1
    M796 Bolster
    MEP-804A
    Wes
  14. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
  15. #20
    Join Date
    Apr 2015
    Glendale,AZ
    Posts
    794
    Thanks
    433
    Default
    Ok, so just clean. Got it !
    1996 M1078 (LMTV)
    2007 4 Door JK
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
