Results 1 to 4 of 4
Thread: 806b AC Circuit Interrupt will not Close... Im in Afghanistan, plz help
  1. #1
    Private
    Join Date
    Dec 2015
    Alpharetta, GA
    Posts
    Thanks
    Default 806b AC Circuit Interrupt will not Close... Im in Afghanistan, plz help
    Gentlemen,
    On a camp that relies heavily on generators. I am a wheel mechanic who does not know much about generators. I have a 60kw mep806b that is not putting out juice. This gen is a replacement for one that is on its last leg. I have to to get this up.
    Good voltage, good frequency, but when the ac circuit switch is flipped.... nothing. Please, any advice on where to begin. I have verified that the actual switch works, btw. New parts are not a option, I have some generators that can be cannabalized from, however.
  2. #2
    Colonel
    Join Date
    Nov 2016
    South Hampton Roads, Virginia
    Posts
    392
    Thanks
    245
    Default
    A start: https://www.steelsoldiers.com/showth...r-the-MEP-806B in case you don't have TMs
    http://www.liberatedmanuals.com/search.mpl?q=806b&Search=Search
    Trouble shooting section - p181/506 in TM 9-6115-672-14 circuit interrupter will not close
  3. The Following User Says Thank You to Zed254 For This Useful Post:
    Light in the Dark (02-01-2019)
  4. #3
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    5,170
    Thanks
    9,170
    Default
    Ok,
    Have you ever seen this thing work right? You say its a replacement, but did it ever work right?
    Are you getting any idiot light on the fault indicator?
    Pull K22 out and replace with a known good one.
    If you flip up the S7 battle short switch, then try and flip up the S5 output load switch, will the K1, AC interrupter close?
  5. The Following 2 Users Say Thank You to Guyfang For This Useful Post:
    Farmitall (02-01-2019), Zed254 (02-01-2019)
  6. #4
    Join Date
    Dec 2015
    Posts
    5,170
    Thanks
    9,170
    Default
    So, sitrep?
  7. The Following User Says Thank You to Guyfang For This Useful Post:
    155mm (02-02-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
