Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 34
Thread: Fuel polishing
  1. #1
    General
    Join Date
    Dec 2017
    Green OH
    Posts
    423
    Thanks
    79
    Default Fuel polishing
    I did a search and didn't come up with anything to conclusive on the subject. I use my own fuel around my place in diesel engines to go through it within a year. I put Biobor and something for lubrication in it when I get it. I do have several gen sets that I have installed that have one or two 55 gallon barrels of fuel onsite for strictly gen set use. It was dosed when pumped, but some of that fuel is two years old now.
    I do use a filter to catch moisture in the smaller bung of the drums when I set up the aux fuel system. That should stop any airborne moisture from getting into the tanks. But any moisture in the fuel already could start to cause a problem long term. What are people doing to polish the fuel to filter out anything? I know we have some pretty smart people in here so I'm sure someone has come up with a system that will work without spending huge bucks.
    The other alternative is to hire a fuel polishing company to come out and work the fuel over a couple times a year. I hate to recommend that as I'd rather do it as part of my regular service work on these gen sets.
  2. #2
    General
    Join Date
    Dec 2017
    Green OH
    Posts
    423
    Thanks
    79
    Default
    This is what I have considered. Let me know your thoughts on this
    https://www.amazon.com/Racor-Polishe.../dp/B00J909BF2
  3. #3
    4 Star General NormB's Avatar
    Join Date
    Jun 2016
    Cloverly,MD
    Posts
    1,165
    Thanks
    2,397
    Default
    Looks like Racor makes 2 micron filters for that rig, too.
    I plan on storing several hundred gallons of diesel at my farm, was thinking about one of these units too, if not just hooking up a pump to one of these: https://smile.amazon.com/iFJF-Separa...eparator&psc=1
    Or similar filter/separator with a 1 or 2 micron filter.
    Question I’ve got is how long and how often to run the filter to maximize any potential benefit.
    It’ll take a lot of research and review from where I’m sitting to find out how much of this kind of “polishing” is done prior to ever dumping it into a gas station’s underground storage tank and how much filtration occurs between that tank and my truck (or 55 gal drum or jerry can) making this process necessary, desirable, or superfluous.
    Thanks for posting.
    NB
    A day without rivnuts is like a day without a Humvee mod.
    MEP-802A TQG 04-2016
    1992
    M1038 W/W 6.2L NA 9-2016
    MEP-803a TQG 09-2018
  4. The Following 2 Users Say Thank You to NormB For This Useful Post:
    Guyfang (02-02-2019), Wolfen (02-04-2019)
  5. #4
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,552
    Thanks
    2,433
    Default
    How much fuel do you plan on using for a $500+ filter to be cost effective?
    Id rather pour out fuel and buy new than to waste money on that setup. I can make you a filter set for less than 300.
  6. The Following 5 Users Say Thank You to gimpyrobb For This Useful Post:
    Farmitall (02-01-2019), gem1410 (02-03-2019), Guyfang (02-02-2019), NormB (02-01-2019), Wolfen (02-04-2019)
  7. #5
    General
    Join Date
    Dec 2017
    Green OH
    Posts
    423
    Thanks
    79
    Default
    If it was just my own fuel it wouldn't be a problem. I'd be using the setup on about a dozen locations with anywhere from 50 to 100 gallons each. That's a lot of fuel to burn on a bonfire!
    What kind of filter setup are you talking about?
  8. #6
    General
    Join Date
    Nov 2016
    South Hampton Roads, Virginia
    Posts
    529
    Thanks
    384
    Default
    Would a "Parker Racor 660R-RAC-01 660R10 Fuel Water Separator 10 Micron w/ Heater Option" from Ebay work? $30 with 30psi / 60 GPH rating. Pipe this filter / water separator up to a fuel pump and run your old fuel through it every other year?
    Attached Images Attached Images
  9. The Following 3 Users Say Thank You to Zed254 For This Useful Post:
    Guyfang (02-02-2019), NormB (02-02-2019), Wolfen (02-04-2019)
  10. #7
    General
    Join Date
    Dec 2017
    Green OH
    Posts
    423
    Thanks
    79
    Default
    Still need some sort of portable pump that can move a decent amount of fuel.
  11. #8
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    5,960
    Thanks
    11,052
    Default
    Quote Originally Posted by smokem joe View Post
    Define portable and decent. Also time frame/period.
  12. The Following User Says Thank You to Guyfang For This Useful Post:
    NormB (02-02-2019)
  13. #9
    Join Date
    Jun 2016
    Cloverly,MD
    Posts
    1,165
    Thanks
    2,397
    Default
    Quote Originally Posted by Guyfang View Post
    That was my question, too.
    How much is enough? How small a particle to remove (knowing a good 10 micron filter will capture smaller ones over time), how long to run and how often?
    Is this even necessary or overkill?
    edit:
    poked around the innerwebs. There's a plethora of information on this esp. among boaters.
    Good article here: https://theboatgalley.com/diy-fuel-polishing/
    YMMV.
    1992
  14. The Following User Says Thank You to NormB For This Useful Post:
  15. #10
    General
    Join Date
    Nov 2016
    Posts
    529
    Thanks
    384
    Default
    I was slinking around the net, too. This guy's operation looks good to me: http://www.alpharubicon.com/altenerg...ishercommo.htm
    I've only got 50 to 70 gallons to worry about so was thinking of filtering the tank during engine testing using one of my spare 803 fuel pumps. Slow, but inexpensive.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
