Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Rhino Tire Carrier With Offset Antenna Base
  1. #1
    Corporal
    Join Date
    Feb 2018
    pa
    Posts
    50
    Thanks
    Default Rhino Tire Carrier With Offset Antenna Base
    Can a tire on an rhino tire carrier clear a offset antenna base when fully swung out?
    a setup like this.
    thanks
  2. #2
    4 Star General juanprado's Avatar
    Join Date
    Sep 2011
    Metairie/La (N'awlins)
    Posts
    3,862
    Thanks
    1,195
    Default
    Yes. On mine it is no problem
    1984 M923 "Maj. Zippidy" who now is equipped like a M925A1
    1991 M998 HMMWV
    1990 Kasel M101A2
    1968 Case Master M101A1 with fuel tank and gen set up
    1991 Eastern Technologies M105A2
    60's ? m116a1? radar trailer flatbed
    xm1073 flat bed 7 1/2 ton
    "Success demands a high level of logistical and organizational competence."
    - General George S. Patton, Jr
  3. #3
    4 Star General 86humv's Avatar
    Join Date
    Jul 2007
    High Desert ca and Texas
    Posts
    1,132
    Thanks
    Default
    The rhino has a drop down safety bracket that prevents it swinging out past side.
    86 hmmwv
    M1102
    M101A2
    Lots a hmmwv parts
  4. The Following User Says Thank You to 86humv For This Useful Post:
    juanprado (02-05-2019)
  5. #4
    Corporal
    Join Date
    Feb 2018
    pa
    Posts
    50
    Thanks
    Default
    I meant does it clear the antenna/base when swinging the tire out 180 degrees from its stored position
  6. #5
    Colonel MarkM's Avatar
    Join Date
    Apr 2008
    MA.
    Posts
    246
    Thanks
    13
    Default
    It swings out until it hits its stop. I have this setup and have no issues.
    Mark
    Attached Images Attached Images
    Heavily Medicated Crime Fighter...
  7. #6
    Corporal
    Join Date
    Feb 2018
    pa
    Posts
    50
    Thanks
    Default
    You have offset mounts on both sides right? Do you know how much wider they make the HMMWV?
    thanks
  8. #7
    4 Star General 1 Patriot-of-many's Avatar
    Join Date
    Aug 2011
    Zimmerman MN
    Posts
    2,104
    Thanks
    790
    Default
    Quote Originally Posted by FirstGen FBody View Post
    thanks
    Wide enough the antennas don't rub on the back cover Just under 89 3/4" at widest part off offsets, rear body is 83 1/2". Rear side reflectors about 84 1/2", door handles roughly 87 1/2-88" Mirrors way more didn't measure....... Take your pick.20190206_115338.jpg
    Like Pringles, you can't have just one.
    Still not banned........
    1991 BMY M936A2
    1990 BMY M931A2 with everything but winch and extensions SOLD
    1984 AM General 923
    1992 BMY M923A2 SOLD
    1998 M35A3 WO/W
    1986 M1009
    1989 M1038
  9. #8
    Corporal
    Join Date
    Feb 2018
    pa
    Posts
    50
    Thanks
    Default
    thanks for measuring, now i have to go measure my garage door opening
  10. #9
    Join Date
    Aug 2011
    Zimmerman MN
    Posts
    2,104
    Thanks
    790
    Default
    You're welcome, but the mirrors are the widest part of the vehicle. Do you plan on folding them every time you park?
    1991 BMY M936A2
    1984 AM General 923
    1998 M35A3 WO/W
    1986 M1009
    1989 M1038
  11. #10
    Join Date
    Sep 2011
    Posts
    3,862
    Thanks
    1,195
    Default
    Offsets can also be pointed facing backwards instead of sideways.
    1991 M998 HMMWV
    1990 Kasel M101A2
  12. The Following User Says Thank You to juanprado For This Useful Post:
    1 Patriot-of-many (02-07-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
