Page 5 of 5 FirstFirst 1 2 3 4 5
Results 41 to 48 of 48
Thread: How do you stop a m809 if the brakes fail?
  1. #41
    Colonel US6x4's Avatar
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    313
    Default
    They make pinion brakes all day long for the axles. Might be a secondary option 5-TON-OVRT.png
  2. #42
    Colonel Ajax MD's Avatar
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    348
    99
    Default
    Quote Originally Posted by US6x4 View Post
    Say, that's very interesting! How is it actuated? Parking brake handle or something else? I'm guessing it's hydraulic and not cable actuated?
    Motorpool:
    (Isn't owning one of this insanity enough??)
    1971 M813 "Ox" (named for Dewey Oxburger)
  3. #43
    2 Star General 319cssb's Avatar
    Join Date
    Nov 2017
    Easley SC
    Posts
    706
    345
    Default
    Oh yeah i remember seeing brakes like that on mud trucks. I think they do that as the wheel brakes usually are wet and full of dirt. That sounds like a great option. I gotta google that.
    I will either find a way, or make one!
    I hate people, who use big words just to make themselves look perspicacious.
    1988 M813
    1987 M1028A2
    1084 M1009
    1997 M1078
  4. #44
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    9,022
    6,096
    Default
    Quote Originally Posted by 319cssb View Post
    There is a lot of information on pinion brakes in this from the Deuce forum.
    Pinion brakes
  5. #45
    Join Date
    Nov 2018
    Mayo, MD
    Posts
    348
    99
    Default
    Quote Originally Posted by porkysplace View Post
    Pinion brakes
    Hm. They ain't all that and a bag of chips. Mainly, I was curious about them as a better parking brake and *maybe* an e-brake in case of service brake system failure.
    Motorpool:
  6. #46
    Former SSG 98G's Avatar
    Join Date
    Aug 2013
    AZ/KS/MO/OK, varies by the day...
    Posts
    4,265
    6,490
    Default
    Quote Originally Posted by Ajax MD View Post
    Consider the rear diff ratio of 6.44:1. This makes a pinion brake useful only for very low speeds (which is where you see them used....)
    Using a pinion brake to try to make an emergency stop from even 45mph will just illustrate how kinetic energy will transform into heat and melt it. There's just not enough room under there to fit in enough mass to absorb the heat.
    Full airbrakes are much to be preferred. Second to that would be a dual circuit (not available for 809series).
  7. #47
    Join Date
    Nov 2017
    Easley SC
    Posts
    706
    345
    Default
    Speaking of 809 , where can i find definete information about the model years. I just saw a 1988 (whaaaaa???) M813A1.
    someone said something about models being still produced after the model ended. I can see that happening for a year maybe . But 6 years?
    1988 M813
    1987 M1028A2
    1084 M1009
    1997 M1078
  8. #48
    Join Date
    Aug 2013
    Posts
    4,265
    6,490
    Default
    I speculate that manufacture dates on the data plates were occasionally changed when going through rebuild. I've seen
    Manufacture dates on 939A0series trucks as late as 2007.
    And we drift off topic.....
  9. The Following 2 Users Say Thank You to 98G For This Useful Post:
    319cssb (02-09-2019), Jbulach (02-09-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
