Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: mep 804a not working.
  1. #1
    Private
    Join Date
    Nov 2018
    charlotte, nc
    Posts
    19
    Thanks
    Default mep 804a not working.
    I have two Mep 804a's. Ill call them Gen 1 and Gen 2. Gen 1 ran perfect, started easily put out the proper power, everything was fine. Gen 2 would not stay running and a low fuel light came on. I noticed the fuel gauge was broken on Gen 2 so i pulled it out of gen 1 and the problem went away but the over voltage light came on. So i put the fuel gauge back in gen 1 and the over voltage light is now comming on in it. Can somebody please help me with this? Both generators are low hour units.
  2. #2
    3 Star General Dock Rocker's Avatar
    Join Date
    Nov 2011
    Jackson ms
    Posts
    906
    Thanks
    190
    Default
    Have you done any troubleshooting? Have you confirmed that it is actually in an overvoltage state with a meter?
  3. #3
    4 Star General /Moderator doghead's Avatar
    Join Date
    Jan 2006
    NY
    MVPA
    8675309
    Posts
    25,884
    Thanks
    2,507
    Default
    Unless you are in an emergency situation, please do not use "HELP" in your thread title.
    Is your power out?
    M817, M818, M819, M35A2 w/w, M35A2, M109, M105, M116A2, M101A2, Pioneer tool trailer, MEP-002, MEP-017A, 5ton winch shear pins, Oral-B toothbrush
    Ah Beefco Industries Northeast marketing associate
    Don't judge a fish by its ability to climb a tree
    https://www.youtube.com/watch?time_continue=12&v=T6BTcEwtmZo
  4. #4
    Private
    Join Date
    Nov 2018
    charlotte, nc
    Posts
    19
    Thanks
    Default
    I have not done any trouble shooting yet but the generators wont stay running. as soon as I let off the start switch well after the oil pressure has built up it still cuts off. Im new to generators like this and have no idea where to start.
  5. #5
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    5,327
    Thanks
    9,535
    Default
    Have you downloaded the TM's?
    Can you use a multimeter?
    Can you read schematics?
  6. #6
    Private
    Join Date
    Nov 2018
    charlotte, nc
    Posts
    19
    Thanks
    Default
    Have not had time to read the tm's and yes I can use a multimeter and read schematics.
  7. #7
    Join Date
    Dec 2015
    Posts
    5,327
    Thanks
    9,535
    Default
    First step might be to look at the wires that go to the meter, on gen set 1. If it worked before you pulled the meter, it should have something to do with how you replaced it back into the Gen set 1. Lets try and get that set back to no problems, before we fool with gen set 2.
    The ground wire to MT5, (fuel meter) is 100AU. The hot wire is 175B.
  8. #8
    Sergeant Major
    Join Date
    Dec 2008
    Near Apex/NC
    Posts
    121
    Thanks
    11
    Default
    I am curious on your choice of MEP 804a generators and your use for them. I also have two 804s to run my 3 phase equipment. These generators and larger sizes are not switchable between single and three phase so they are not as useful for backup power in most residential situations. Also, after starting with an over voltage light, do you clear it and it then comes back on? Mine will do that from time to time.
    Robert
  9. #9
    Join Date
    Dec 2015
    Posts
    5,327
    Thanks
    9,535
    Default
    Quote Originally Posted by robertsears1 View Post
    Robert
    Robert is correct. Sometimes you get a failure light, and its got to be cleared before going on.
  10. #10
    Private
    Join Date
    Nov 2018
    charlotte, nc
    Posts
    19
    Thanks
    Default
    Thank you. Im off this afternoon and i will take a look when i get home.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
