Results 1 to 2 of 2
Thread: Globe GTTU 202 - Tag Trailer - Engineer Equipment Trailer (EET) x 2
  1. #1
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,375
    107
    Default Globe GTTU 202 - Tag Trailer - Engineer Equipment Trailer (EET) x 2
    2 of these for sale. - LED lights. Flat deck. 20 ton on road rated capacity. 10 ton offroad. Super Single 385/65/22.5 tires with a spare tire/wheel. Conex Locks. ABS equipped. 30ft overall. 19'4 ft deck with 4ft6" dovetail. 8ft wide. Conex box not included. Air brakes all work and adjusted properly.
    Clear titles. $7500 each. Located near Nashville. Delivery can be arranged for a fee.
    These trailers are the newest EET trailers with no wheel wells and a frame cut to allow dual tires to be mounted.
    Attached Images Attached Images
    2008 F-250 6.4L Powerstroke
    1984 AM General M923A1 ( Big Cam III NTC-400, HT3B turbo, Intercooled, #15 button, Dual fuel Line setup - MRAP Aluminum Radiator - 8" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    83' M923A1
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  2. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    Russ Knight (03-05-2019), silverstate55 (03-14-2019)
  3. #2
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,375
    107
    Default
    1 trailer remaining
    83' M923A1
    M796 Bolster
    MEP-804A
    Wes
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
