Fire Extinguisher
NormB
77
Cloverly,MD
Got thinking about this a few years back when I got my 802a. Nice thing to keep around.
I already had the standard ABC powder FE in my HMMWV - since I'd updated to the OEM high-back seats, it went right by the seat on the floor where it's out of the way and easily accessible (some mechanical engineer must've had a triple espresso mochachino that morning and really thought this one through), then I got a halon (halotron) 2.5lb model I bolted down to the frame cross-member behind the seat.
https://smile.amazon.com/gp/product/B00CMUMW5C/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
What REALLY got me motivated was a fuel leak from the secondary fuel filter (the metal bowl with replaceable cartridge just before the distribution pipe) that dumped about a gallon of #2 diesel into the set which I only noticed because it was dripping, pooling on the garage floor (where I have a couple of FEs scattered around).
I did this yesterday:
Since I do a "walkaround" on the set before firing it up anyway, looking for debris, nests (inside and out), fuel or coolant leaks, etc., I take out the FE and put it within arm's reach of the genset just in case. Cheap insurance.
I used 1/4-20x1/2" stainless flanged bolts, but #8 yellow zinc lock nuts (not nylock, the other ones with the crimped opening), then a cutoff wheel on dremel tool to cut 'em off flush with the nuts so the FE would lock down.
I was thinking about a 5# CO2 FE for this, but couldn't figure out where to mount it inside the set).
Now on to indoor plumbing repairs...
NB
simp5782
Feo, Fuerte y Formal
9,248
Mason, TN
I keep a few of the tactical ColdFire extinguishers in my trucks. The normal fire extinguishers just have a hard time with burning paper if the wind is blowing and the cold fires still put it out.
M35A2-AZ
380
Tonopah, AZ
Nice, I have started to replace the older ABC one and buy CO2 one for the trucks. But your right the CO2 one are bigger.
Storm 51
Just a Grunt
9
Seattle, WA
I use Halon extinguishers in my truck, trailer and garage. They are a little more expensive, but there is no corrosive destruction to the vehicle if you have to use one. After seeing what happens to wiring and other equipment when standard commercial extinguishers are used, I think Halon is well worth the money.
They are the standard extinguisher on aircraft for many reasons.
Just something to consider.
Keith_J
1,313
Schertz TX
Ive used Halon, CO2, ABC and Purple K for B and C class fires, I am not impressed with Halon for petroleum fires as it has far less cooling capacity compared to carbon dioxide. Halon knocks the fire down for certain but the danger of flashback is there if the fumes from the fuel contact metal above the autoignition point. Nothing beats 20 pounds of carbon dioxide, good duration and dry ice snow cools great.
Now in an aircraft? Different story as there is far less heated metal issue compared to surface vehicles.
Storm 51
Just a Grunt
9
Seattle, WA
I'm more concerned with electrical fires than fuel or paper fires with my truck. CO2 is also a good way to avoid the severe corrosion caused by other units.
CO2 extinguishers certainly have multiple uses.
Chainbreaker
1,810
Oregon
OK, so I'm convinced that a CO2 extinguisher would be good to have around. I looked on Amazon at 10 lb CO2 extinguishers and they run right around $300 each! Why do they cost so much as compared to ABC extinguishers? Where does one find one that is more economically priced?
