Results 1 to 3 of 3
Thread: 97' 3116 oil pressure sender
  1. #1
    Sergeant Major jkcondrey's Avatar
    Join Date
    Mar 2017
    Rutherfordton, NC
    Posts
    130
    Thanks
    51
    Default 97' 3116 oil pressure sender
    I have a 97 LMTV with the 3116. I have crappy readings for oil pressure. I checked with my mechanical tester to verify. I am looking to replace the sender, after checking wiring and cleaning up the connections. The part # on the current sender is 12420859 with another mfg # of 7z634. TM-P # came up non orderable. It came up under part target # but they wont sell to me personally. Does anyone have experience with a NAPA part that will work for this? I tried the cross reference at napaonline and came up with nothing. I searched on here, 3116 oil sender, 3116 oil pressure, etc with no part #'s to be found for anyone that replaced them. I am sure someone else has replaced one. Thanks in advance.
    1997 LMTV-LVAD
    1968 AMG m35a2 (crew cab construction currently)
  2. The Following User Says Thank You to jkcondrey For This Useful Post:
    Adventure Driven (03-13-2019)
  3. #2
    4 Star General dmetalmiki's Avatar
    Join Date
    Aug 2006
    London England
    Posts
    4,401
    Thanks
    510
    Default
    Go with a mechanical capillary gauge.
    Easy fit, Same pattern, accurate, and what you see is what you got!.
    DIAMOND T M20.
    M54A2 I.H. M62. wrecker
    M54A2 5 Ton (with Radio Body. ex praga command station)
    M45 530C fire truck
    M561 Gamma Goat
    1942 Ford Jeep (with underfloor tulsa winch)
    1945 Willys Jeep (with V8 flathead Engine) And now 'that' overdrive'..
  4. The Following User Says Thank You to dmetalmiki For This Useful Post:
    jkcondrey (03-13-2019)
  5. #3
    I'm the dude, man. Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    6,771
    Thanks
    106
    Default
    You can use a Stewart Warner 279A sender in its place. Found at parts stores or on Amazon
    2008 F-250 6.4L Powerstroke
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, Oshkosh 55000 Transfer Case, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  6. The Following User Says Thank You to simp5782 For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
