Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
Results 41 to 50 of 92
Thread: Resurrecting an M108
  1. #41
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    Got the engine back in a few nights ago. Had a little delay because the starter on the forklift went out and I had to replace it so I could pick up the engine. I ran in to a small problem. Like a dummy I didn't take good pictures of everything before I started taking two trucks apart and now I have a line I don't know where goes. It's the smaller of the two lines on the breather pipe that goes to the ground. I thought when I hooked everything up it would be really obvious but no luck. Any ideas?
  2. #42
    4 Star General SETOYOTA's Avatar
    Join Date
    Feb 2005
    georgia
    Posts
    2,200
    Thanks
    Default
    Do you know the part number of the socket you got from NAPA? Did you figure out where the line went? I could not exactly tell what line you needed info on.
    Have owned A whole bunch of jeeps, trucks and armor. Still have a few.
    I love my carbon footprint and no I don't own a Toyota.
  3. #43
    4 Star General Jeepsinker's Avatar
    Join Date
    Aug 2013
    Dry Creek, Louisiana
    Posts
    5,188
    Thanks
    1,203
    Default
    Quote Originally Posted by Redpawn View Post
    One to air pack, one to fuel tank vent.
    I sink Jeeps... That is all
    1969 Kaiser Jeep M35a2 w/winch (Daily driver, no joke)
    Now a hot rod deuce: 6BT swap in progress, Waterloo overdrive, 2 micron fuel filtration installed, riding on 11.00r20s
    1971 M151A2 w/ ROPS
    3: 87' M35a2c Air Force trucks
    1991 BMY M936a2 wrecker
    2: M1061 flat trailers
    1: Fresh rebuilt and load tested good Mep003a genset
    I do Fort Polk and other recoveries in my state. I can be reached at 337-401-2470
  4. #44
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    SETOYOTA The socket is a Carlyle part number 61-4046
    Jeepsinker Your saying the smaller one should run all the way back to the vent on the fuel sending unit? I took all lines off the frame of the M35 and it had the small line coming off the fuel sending unit going to a t fitting in the line running from the air pack to the breather. I.E. the one I have hooked up in the picture. Should I take the t fitting out and run it all the way to the breather or just plug the line in the breather?
  5. The Following User Says Thank You to Redpawn For This Useful Post:
    SETOYOTA (05-19-2019)
  6. #45
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    While putting all the shifters back in I found my transfer case PTO would not engage. I pulled the linkage off and tried to engage it and still nothing. So I printed the manual and pulled the PTO off to rebuild it. Found the problem pretty quick. Some one had been in it before and did not tighten the set screw for the shift fork and put it on backwards. I decided new bearings and seal would be a good idea. The problem now is new bearings are tighter and I don't have enough shims to re shim it properly. I can find the shims for the transmission PTO but not the ones for the transfer case PTO. Anyone know where to get them or do I have to make my own?
  7. #46
    Join Date
    Feb 2005
    georgia
    Posts
    2,200
    Thanks
    Default
    Try Memphis equipment .
  8. #47
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    No luck. I've checked boyce equipment, eastern surplus, big mikes motor pool,those military guys, eriks military surplus and now memphis. The only one who had anything at all was eastern and all they have is a complete unit. Looks like I might be making my own shims.
  9. #48
    Join Date
    Feb 2005
    georgia
    Posts
    2,200
    Thanks
    Default
    Did you try seco in Augusta Ga ?
  10. #49
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    It looks like the're parts catalog is down right now.
  11. #50
    Sergeant Major
    Join Date
    Aug 2008
    St.Cloud FL
    Posts
    122
    Thanks
    22
    Default
    Since no shims could be found I just made a new one. Here's my shim and the newly rebuilt PTO. Has anyone ever seen a Ramsey PTO for a deuce? I have one on a case that I took out of a truck I scrapped but I haven't been able to find any info on it.
    IMG_20190525_185531.jpgIMG_20190525_185544.jpgIMG_20190525_214809.jpgIMG_20190525_220358.jpg
  12. The Following 2 Users Say Thank You to Redpawn For This Useful Post:
    Evil Dr. Porkchop (05-25-2019), SETOYOTA (05-25-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
