- 1,397
- 566
- 113
- Quantico VA
Subscribed
My 6.2 only had about 2/3 throttle movement before adjusting the cable so I can mirror this commentMake sure you are not losing throttle movement through loose linkages/cable stretch from the foot pedal to the injection pump. Floor insulation can also limit movement. I have seen humvees that when the pedal was to the floor, the injection pump was less than 65% throttle. Also make sure the linkage from the injection pump to the trans is setup correct (cable just tight at idle). These 2 things are the first thing i look at for better performance.
TSteve, I think there’s gonna come a point where I am going to ask if I might send my vehicle to you or someone like you to shake it out and install a turbo engine with turbo doghouse. I’ve been thinking about it for a while. I also respect your dim view of Central tire inflation system how ever if you have one available, I will probably have you install it.
In the mean time, a small HP boost would be nice. If I need to install EGT sensors, so be it.
As always, thanks for your insight and answer.
