Results 1 to 3 of 3
Thread: Slipjoint np205 passenger side drop
  1. #1
    Colonel skysix's Avatar
    Join Date
    Feb 2009
    Ft Hunter Liggett, Adin Mariposa Merced Portland Edmonton West Bragg Creek, - depends on the week!
    Posts
    334
    Thanks
    333
    Default Slipjoint np205 passenger side drop
    Looking for a working M1031 or M1028A1/A2 transfer case on the west coast
    SECM M1031 becoming a "M1031E2" (DRW, Utility Box & 16k GVW)
    You don't own it if you can't take it apart - and don't take apart anything you can't put back together again!
  2. #2
    Big wheeler cat peeler Valley Rock's Avatar
    Join Date
    Aug 2018
    Rogue Valley OR
    Posts
    86
    Thanks
    119
    Default
    If you don't find a complete unit I believe have a SY output shaft complete with housing up on the mezzanine, you could convert a standard or I could maybe make one for you, or I could hand you the parts and make it yourself, there are several 205s up there, 6 bolt NP pattern on all of those if I'm not mistaken
  3. #3
    Join Date
    Feb 2009
    Posts
    334
    Thanks
    333
    Default
    Thanks all for the help but I lucked out and found a LoMax 205 so will be going with a 1410 flange output and a double cardan mid-shaft slipjoint driveshaft
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
