53” 16.00 R20 YZL on 2005 M1088
Cgray
21
Lake Geneva, WI
53” 16.00 R20 XZL on 2005 M1088
I do not have high speed gears or lockers.
Yes is is possible to do so without modifications.
PROS:
1.) Max Speed increase from 58 to 73
2.) Better gas mileage if you limit your speed to 60 mph on long hauls.
3.) Looks badass
CONS:
1.) Max speed of 73 is a bit fast for this 10 ton beast.
2.) Small amount of plastic trimming optional
3.) Slower hill accent speed with weighted load.
Overall recommendation is to do this install.
coachgeo
3,334
North of Cincy OH
What is the load rating of the particular 53's your considering? Speed rating of G is I believe 56mph and J is 62mph. Of course that is only if your inflated with in the specs of the tire.
Do believe most of the Military 53's are speed rating of G. so 55mph max should be considered..... calculate engine rpm at that to see if that puts the engine in a sweet spot with the results of the 53 on overall ratio
Cgray
21
Lake Geneva, WI
I considered that as well. Contacted manufacturer and was told that the speed ratings are only for full load rating of tire. So in short, I don’t believe I’ll ever fully load these tires out and if I ever did I sure the **** wouldn’t be going over 55.
My idea was as you speak of in last paragraph. Lower RPM, same highway speed and better gas mileage.
Ill take a photo of load ratings later this morning. Working on installing an tach to keep track of RPMS. Maybe it will become useful in the future. I would love to achieve that magical 10+ MPG.
ramdough
1,727
Austin, Texas
Don’t forget the age of the tire might reduce the speed you want to go.
That does look pretty cool. I would love to hear how you like it.
Do you go off-road much? Would like to hear if they hit anything when flexing.
Sent from my iPad using Tapatalk
coachgeo
3,334
North of Cincy OH
I considered that as well. Contacted manufacturer and was told that the speed ratings are only for full load rating of tire.....
agree with you there and have in past brought that up. There are plenty of tire models where they rate speed based on PSI and load..... unfortunately NOT for any of the tires as large as ours.... so that puts us in a legal limbo.
Cgray
21
Lake Geneva, WI
I’ll try to make a video or at least pictures of it Offroad this weekend. See what I can pull off.
Plan an is to definitely use it Offroad as much as on.
