Major issue after installing 16:00's
Lukes_deuce
123
Long Island, NY
Anyone happen to know the diameter of the torque rod end bolts? I'm considering having a set of adjustable torque rods built in order to give a small amount of adjustment when running 16:00's. Thoughts?
While it sounds like a good idea to have adjust-ability, the axles need to be square to them selves and to each other, or your going to have more problems. Have you checked your trunnion bushing to see if that has play in it? The space in between the wheels needs to be the same on both sides. I can see a little play but there shouldnt be anything noticeable unless something else has failed in the suspension. The dog bone bushings are really fixed connections. They might flex over rough terrain but not when your on flat, level ground. I feel like something else is up. Dog bones are not drag links or tie rods.
topo
219
farmington NM
The torque rods used on trailers is only one inch shorter then the torque rods used on trucks .
trailer 28 1/4 black
truck 29 1/4 green
maybe at one time the wrong torque rods where used
Russ Knight
1,051
Perry, FL
I need some bridge truck bones, springs, and driveshafts. I think they're an inch longer.
simp5782
Feo, Fuerte y Formal
9,256
Mason, TN
For what it would cost to find those you can cut and extend the current dog bones with channel, add 2 lower long leafs and your between axle driveshaft will still work for the inch difference
Something is just offset somewhere. Or like he said one dog bone is shorter. It has happened before. Knowing where that truck came from they just threw a part on it that they had
Scrounger
65
Southern, Maryland
Before redesigning the truck why not figure out what the problem is? As Wes has posted something is not lining up. If you were able to separate the tires with a come a long something is loose. Look for new rust, loose bolts, and measure things. Make sure all the torque rods are the same length.
porkysplace
1,485
mid- michigan
Something is worn out . If 1 dogbone was shorter than the rest there would have been unusual tire wear on the old tires.
Russ Knight
1,051
Perry, FL
I have inspected the suspension as best that I know how. Nothing is bent or worn that I can tell. All dogbones are green (haven't measured them yet) and rubber bushings look good. Spring position on both sides appears uniform. Even with a 4 ton come a long double blocked, I was only able to move the rear axle back about 1/2" to separate the tires in order to get the truck home.
Lukes_deuce
123
Long Island, NY
Im still going with something is broken or wrong dog bone. I suggest to find the same model 5 ton that is known to be straight and take measurements. Something is off, you just have to find it. New tires do not make a good suspension wrong all of a sudden.
simp5782
9,256
Mason, TN
Post some pictures of what you have going on Russ as well as some underside pics.
You may even measure the lower dog bones to make sure they are all the same. Contrary to porkyplaces statement. If you dont drive something alot to cause an unusual tire wear it wont show. Not to mention also even an axle canted like it's under load it wont wear that obvious either. Unless its heavy road driving. not to mention the Goodyear at2s just scuff up over wearing the edge in the rears. Especially with a throttle load vs without one
simp5782
9,256
Mason, TN
Incredible life. Still tread left too. Never would have guessed that for that tread design. What is the tread wear rating for them?
They are rated for 14,500lbs each. So basically I am hardly ever at 9000lbs a tire really even with a full bed or lots on tongue weight. I have maybe 8 to 10k left in the rear
