Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: H-1 Ground Support Heater, NSN 4520-01-056-4269
  1. #21
    4 Star General Wire Fox's Avatar
    Join Date
    Nov 2012
    Indianapolis, Indiana
    Posts
    1,087
    Thanks
    374
    Default
    Quote Originally Posted by Guyfang View Post
    It doesn't have a vent position? To vent the burner chamber? Is the flame controller a photo electric device?
    "vent position" would be just switching the burner itself off, as the blower is on if the engine is on (direct mechanical drive). That main 3-pos switch controls the engine. The burner is operated on a separate circuit, which has safety sensor interlocks for high temperature, airflow, and presence of flame. Lack of any of those will cutoff the power to the ignition coil and fuel solenoid for the burner itself.
    1994 M998A1, 2-dr, 6.5L GEP NA
    Checkout my build thread! http://www.steelsoldiers.com/showthr...ild-in-Indiana
  2. #22
    Join Date
    Nov 2012
    Posts
    1,087
    Thanks
    374
    Default
    Attached is the way easier to read schematic, with my annotations of info pulled from the text of the patent.IMG_20190612_173344.jpg
    Sent from my Nokia 6.1 using Tapatalk
  3. #23
    Join Date
    Nov 2012
    Posts
    1,087
    Thanks
    374
    Default
    Confirmed that the unit is indeed...wired wrong. And the spare panel I have? Also wired wrong. Both of these are setup with 24V going straight to the power input. I spent some time carefully reading the water-damaged label on the ignition control module and was able to decipher 05-159901-003. This P/N crossed over to NSN 4520-01-065-3858, which immediately points back to being a part for a Davey / DRS H-1 heater. Perfect! Also good: I found a cheap replacement part online ($23 delivered, sealed in military packaging) that so happens to have a very legible label. Attached the picture below... As well, I found a Kidde-Fenwal reference sheet. This obsolete P/N crosses over to be a 35-530501-103 (Doesn't appear to be a 1:1 replacement, also was declared obsolete). An additional note stated "COLEMAN 4322-321, DIRECT REPLACEMENT" I found the old datasheet as well, so attaching it (includes P/N for wiring harness, P/N for the electrode assembly that has same dimensions as what's in the heater, the gap measurements for the electrode, and a block diagram of this unit)...
    As you can see, the input clearly states it's supposed to be 12V. Sadly as well, I found no trace of a resistor inside the control box assembly to try and measure any value for the prior schematic. What might the value be?
    (As a voltage divider, the actual calculation for the two voltage sources with the unknown resistance looks beyond my pay grade.)
    Worst case, I can just tap off of a single battery and completely disconnect the 24V side. That should at least provide the ignition controller with a safe 12V for operation, just forcing me to keep my eyes on the batteries for regular maintenance. Alternatively, I could just replace it with a 24 VDC model and gamble on all of the rest of the specs being right... 24VDC input, 24VDC valve, no purge cycle, 6.8 sec flame establish time... Hypothetically would be 35-405200-003, but I'm getting no hits for it being out there. (And at $23 vs $250, it's more cost effective to make the original 12V unit work...)
    Attached Files Attached Files
  4. The Following User Says Thank You to Wire Fox For This Useful Post:
    Guyfang (06-13-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
