Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 40 of 40
Thread: MV Addiction filled. Reis the Beast M1078A0 is born
  1. #31
    4 Star General coachgeo's Avatar
    Join Date
    Nov 2010
    North of Cincy OH
    Posts
    2,359
    Thanks
    818
    Default
    Quote Originally Posted by M1078MAN View Post
    Yes they are, going to see if i can make them work
    work for what?? ctis covers orr?
    One does not get troubles in life... just character building opportunities. Build on with a smile
    Moderator: Orange Tractor Talks & AmbulanceRV
    Daily driver- 99 VW TDI or 2002 KLR DIESEL w/cvt... weather permitting
    Projects: 96 M1078, 97 Triumph Tiger w/3cyl Diesel Kubota
    Sold: 1962 Dieselized Unimog 404, 1984 Int. 24foot Flatbed, 97 Jeep TJ heavily Modified, Datsun Roadster(s) & 510(s)
  2. #32
    Sergeant Major M1078MAN's Avatar
    Join Date
    Jul 2018
    SW Va, Roanoke County
    Posts
    134
    Thanks
    72
    Default
    yes, ctis armor...
    Retired MIL/ US DoAG CIV
    1st MV 1995 M1078 (shes home)
    --Support Equip AX56L Acutemp Fridge Freezer
    --Model 10000MDP-CS Ready Welder II
  3. #33
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    Today was a great day..a SS Brother in Arms came to my rescue and sent me a CTIS Module, no name, a PO box in Ashville NC.
    Who ever you are, thank you brother!.....I wont post any additional info about you.
    After checking out the part numbers, and they matched, I took it out to the truck, and plugged her in. I now have flashing single light and all mods select-able. Now i just need to do some additional trouble shooting to why i have no working inflate or deflate.
    Also, a great day, mail call
    Recd these HET CTIS covers thanks to fleaBa. A little nip and tuck and they just might work, bolt holes look like they will line up, but they wont.
    got to do some slicing and dicing, but great platform to start with
  4. #34
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    Always welcome /Mail Call\
    Thanks to the Amaz-on, picked up the 150 lb CTIS transducer
    Search AUTEX Pressure Transducer/Sender/Sensor 150/200 Psi Stainless Steel Compatible With Oil, Fuel, Air, Water (150 Psi)
  5. The Following User Says Thank You to M1078MAN For This Useful Post:
    DREDnot (06-15-2019)
  6. #35
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    /Mail Call\- today, thanks to Amaz-on, recd 199 M4x.7 blind rivnuts.
    28 PAOZZ 84256 ALS3-470-2.0 NUT,PLAIN,KNURLED M4X.70 (GRIP 16
    Search CAK2-470-3.3, RIVETNUT, M4x0.07 (2.01-3.30mm GR) RND Body Splined, Low PRO HD, Steel, Zinc YLW (100 PK)
    /Spent the day pressure washing, cleaning windows and waxing the carc [shinning the tires], going to enter truck of the day comp\
  7. The Following User Says Thank You to M1078MAN For This Useful Post:
  8. #36
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    Today was spent trouble shooting CTIS, and after a few hrs, think i have stumbled on the problem. I found that the right rear CTIS LINE TO TOP OF HUB WAS BROKE CLEAN OFF at the connection, hose only..Will get a line and see if that solves my problem.
    Question, as a test, can i by pass the pressure switch just by jumping the two wire connector
  9. #37
    4 Star General Steel Soldiers Vendor Suprman's Avatar
    Join Date
    Feb 2013
    Stratford/Connecticut
    Posts
    6,389
    Thanks
    24
    Default
    The pressure switch on the air tank? Yes I use a paperclip.
  10. The Following User Says Thank You to Suprman For This Useful Post:
    M1078MAN (06-17-2019)
  11. #38
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    Quote Originally Posted by Suprman View Post
    Yes, good deal, I thought I remember doing that, but been 10 years
    Here is the carnage i found and after i took the hub side connector off. you really could not see it
  12. #39
    Sergeant Camel Driver's Avatar
    Join Date
    Dec 2017
    Gilberts Illinois
    Posts
    81
    Thanks
    14
    Default
    "think i have stumbled on the problem."
    Myself, I will take lucky over good any day if it saves me time and frustration. Here's to many more "lucky" problem fixes!
    BTW, you are making me very jealous. I was hoping to be working on our M1083 at the pace you are going. Unfortunately, I decided to go back to work at a "real job" for a while just to stash away some extra funds for the truck. But I will definitely be watching your progress with interest. Both for the good info and to do a little vicarious living.
    Keep up the great work, Bill
  13. The Following User Says Thank You to Camel Driver For This Useful Post:
  14. #40
    Join Date
    Jul 2018
    Posts
    134
    Thanks
    72
    Default
    /MAIL CALL\ Today i had a nice surprise, the following was delivered ahead of schedule..I need a few more, just couldn't spend the 400 bucks
    TM 9-2320-365-10
    Change 2
    C-3
    Section II.
    ADDITIONAL AUTHORIZATION LIST (CONT)
    (1)
    National Stock
    Number
    (2)
    Description
    Usable On
    CAGEC & Part Number
    Code
    (3)
    U/I
    (4)
    Qty
    Auth
    2540-01-489-5928
    KIT, RIM COVER
    57K199
    ctis cover.jpg.
    I guess I spoke too early, anther delivery, both via fleaba
    9150-00-223-4134
    9150-00-082-7524
    9150-00-265-9408
    Hydraulic Fluid, Petroleum Base
    (MIL-H-5606) (81349)
    1 qt can
    1 gal can
    10 gal drum
    55 gal drum
    qt
    gal
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
