Results 1 to 9 of 9
Thread: what Happened to my M1101
  1. #1
    Private
    Join Date
    May 2019
    Mercer Island, WA
    Posts
    12
    Thanks
    Default what Happened to my M1101
    So I got a 2009 Silver Eagle M1101 trailer from GovPlanet. I got it shipped on a trailer and was working on it, e.g. LEDs, wiring harness, painted, bed liner, tagged it, etc... When I was moving it around on my property and neighborhood, it was rolling fine. I was going to take it to a local tire store to switch out a tire (flat spot that looked like someone dragged it around the parking lot with break on) and pack/grease bearings. Well, the whole **** wheel came off! Luckily, I was at the entrance to a parking lot in local park. It looks like the entire axel was recently replaced as it has a silver Schutt tag on the axle with a part date of 2017.
    Not sure if I need a new rim or if it was a bearing issue that needs to be replaced. Also, can anyone suggest a good place to get parts, if you can tell from the picture what is needed?
    Thanks for you thoughts on this...
    Attached Images Attached Images
  2. #2
    4 Star General
    Join Date
    May 2013
    Posts
    4,138
    Thanks
    2,612
    Default
    Your brake parts are not in their proper position, are any of them obviously bent? Will they go back into position? Looks like the axle will clean up and you may need a hub, bearings and (maybe) brake drum. With the bearing races out, can you clean the hub to work again?
    Get bearings for the other side while your doing it.
    M35A3 4x4 "Money Pit"
    M929A2
    (14) 5 tons bought and sold
  3. #3
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    9,066
    Thanks
    6,149
    Default
    This is what is in the TM section for your trailer;
    TM9-2330-392-14P.pdf
    TM9-2330-392-14P Operators, Unit and direct support and maintenance manual for M1101 series trailers.
    MWO_pt1_M1101.pdf
    MWO_pt1_M1101 MWO part one for M1101 series trailers.
    MWO_pt2_M1101.pdf
    MWO_pt2_M1101 MWO part two for M1101 series trailers.
    : M1101 Bearing set
  4. #4
    Sergeant Major
    Join Date
    Mar 2012
    oklahoma city, ok
    Posts
    189
    Thanks
    Default
    One thing I don't see is a cotter pin for the castle nut. Could explain the wheel falling off. Please check the other side before moving the trailer again. Possible whoever built that axle missed that step somehow.
  5. #5
    4 Star General NDT's Avatar
    Join Date
    Dec 2008
    Camp Wood/LC, TX
    MVPA
    4954
    Posts
    7,402
    Thanks
    2,166
    Default
    I sure don't see much grease on the remaining bearing. Maybe someone assembled it dry.
  6. The Following User Says Thank You to NDT For This Useful Post:
    SCSG-G4 (05-17-2019)
  7. #6
    Sergeant Major MississippiRifle's Avatar
    Join Date
    Jan 2014
    Poplarville, MS
    Posts
    128
    Thanks
    25
    Default
    Quote Originally Posted by NDT View Post
    Yup. Ran it dry. Burned up the bearing.
    "A man has got to know his limitations." Harry Callahan
    1972 M35A2 Deuce
    2004 M998A1 HMMWV
    3,000 gallon collapsible water bladder
    M447 Electrical Shop Van
    2 X 2008 M1101 trailer
  8. The Following User Says Thank You to MississippiRifle For This Useful Post:
  9. #7
    Private
    Join Date
    May 2019
    Mercer Island, WA
    Posts
    12
    Thanks
    Default
    I also had a member send me a link regarding over torque issue on M1101 trailers... https://www.steelsoldiers.com/showth...-recall-notice I have the trailer at a local shop and will definitely ensure the bearings are greased and properly assembled...
  10. The Following User Says Thank You to DamiansAR15 For This Useful Post:
  11. #8
    Private
    Join Date
    May 2019
    Mercer Island, WA
    Posts
    12
    Thanks
    Default
    I also connected to my mechanic and he mentioned that there was not any grease on the bearings, which seems to align with earlier posts, e.g. burned up the bearing... My mechanic is working on getting bearing parts and I have a bad break line. I also will need to flush/bleed Dot5 brake fluid, as I think there was water in the brake fluid, e.g. found crack in cheap plastic cap.
    Thanks folks for thoughts/feedback...
  12. #9
    Super Moderator Tinstar's Avatar
    Join Date
    Aug 2013
    Edmond, Oklahoma
    Posts
    3,593
    Thanks
    920
    Default
    Now you know why guys check the bearings, etc when they first get them.
    Bad bearings, loose nuts, missing parts and no grease.
    1987 M1008A1 (2)
    1986 M1009
    1995 NF2D FloodLight/Kohler-Kubota Generator Set
    1992 M101A2 trailer (2)
    1987 M149A2 Water Buffalo (M149A1 Chassis)
    S-280 Shelter
  13. The Following User Says Thank You to Tinstar For This Useful Post:
    SCSG-G4 (05-19-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
