Results 1 to 8 of 8
Thread: Can my Jerry can be used with diesel?
  1. #1
    Colonel US6x4's Avatar
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    215
    Thanks
    Default Can my Jerry can be used with diesel?
    The word on the street is that diesel in a galvanized can or fuel tank is bad because the diesel dissolves the zinc which gets into your injection pump. So I have this 1986 USMC can that is galvanized on the outside for sure but the inside has a smooth slippery tan coating. The can is stamped G - could this be to call out Gas only?
  2. #2
    General Gralmk's Avatar
    Join Date
    Jul 2014
    Attleboro, MA
    MVPA
    36166E
    Posts
    564
    Thanks
    190
    Default
    Yes. But the problem is they rust and that's what will mess up ya fuel system. Better to have one of the newer plastic ones. Use the metal one for display only.
    And yes I know if you maintain them they'll be fine. I used them In the Military for 40 years so I know you can. Also make sure the ears on the cap are rolled over, if they are straight up its probably a water can. Sometimes stamped water, sometimes not! The G might just mean government. Never saw one with a D?
    1981 M35A2
    1985 M1010
    In the Family:
    1985 M1009
    1952 M38
  3. #3
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    215
    Thanks
    Default
    The ears are straight up with no water markings anywhere. Could that mean that the internal coating may not withstand fuels? It smells like the can formerly held gasoline.
  4. #4
    Join Date
    Jul 2014
    Attleboro, MA
    MVPA
    36166E
    Posts
    564
    Thanks
    190
    Default
    OK, the more I thought about it the water cans should have had a flip down type cover! The ears should not matter I think they just meant age of the can or maybe mfg? Again we used them for years until the plastic ones came out, got rid of the possibility for getting rust into the tank. Never had any knowledge of any other issues! To in 25 years never changed an IJ Pump! Oh and I have seen both gas and diesel used in everything, to include water cans, which of course ruined them. But anything goes!
    Rick
    1981 M35A2
    1985 M1010
    In the Family:
    1985 M1009
    1952 M38
  5. #5
    Moderator WillWagner's Avatar
    Join Date
    Mar 2006
    Posts
    7,145
    Thanks
    116
    Default
    I have 5 of those cans dating from the mid 60s to mid 80s. I used them for diesel when I had my Deuce and still use them for gas for my jeep. They will be fine as long as you don't let water sit in them.
    ASMH Volunteer
  6. The Following User Says Thank You to WillWagner For This Useful Post:
    SCSG-G4 (05-17-2019)
  7. #6
    2 Star General fasttruck's Avatar
    Join Date
    Jan 2009
    Mesa, AZ
    Posts
    654
    Thanks
    Default
    Water cans have different tops than fuel cans. Steel water cans have a cam lock top and plastic ones have a top that screws over the top of the can and fuel cans have threaded female openings to accept the dispensing spout. As mentioned before the water cans also have a smaller cap fitted to the big cap to allow dispensing small quantities of water to fill a canteen or what not.
  8. #7
    PSVB 3003 SCSG-G4's Avatar
    Join Date
    Jun 2008
    Lexington, South Carolina
    Posts
    4,189
    Thanks
    12,568
    Default
    Either during or slightly after WWII the military came up with an easy way to distinguish water cans from fuel cans. Water cans have ONE handle, Fuel cans have THREE handles. Not to say that water cans have not been used for fuel, but I hope not vice versa.
    Mike KK4AIF
    M109A3 Shop Van (G4-38 )
    M35A2 Cargo Truck (G4-39)
    S-280 Commo Shelter (bunk house on M-36)
    MKT-85 Kitchen Trailer (G4-T1)
    M36A2 Cargo Truck (G4-40)
    2nd M35A2 Cargo Truck (G4-41)
    3rd M35A2 Cargo Truck (G4-43)
    2nd M109A3 Shop Van (G4-42)
    MJQ-18 Trailer (10 KW Power Plant) (G4-T3)
    MKT-85 Trailer as FST (G4-T4)
    MJQ-16 Trailer as Contact Maintenenance Body frame (G4-T5)
    M105 Tan trailer
    MJQ-18 Trailer as a bunk house under construction (G4-T2)
    M-149 Water Buffalo (G4-T6)
  9. The Following 2 Users Say Thank You to SCSG-G4 For This Useful Post:
    firefox (Yesterday), tbearatkin (05-17-2019)
  10. #8
    4 Star General Steel Soldiers Vendor Evil Dr. Porkchop's Avatar
    Join Date
    Nov 2011
    Colchester, VT
    Posts
    1,774
    Thanks
    607
    Default
    Quote Originally Posted by SCSG-G4 View Post
    All the steel and aluminum water cans I've seen still had three handles. The plastic water cans had one handle versus the three on fuel cans but those didn't show up until the later 1960s I believe.
    m151a2, m1028s, m59 dump truck, LCVP, m416, m101a2, m101a3, m104
  11. The Following User Says Thank You to Evil Dr. Porkchop For This Useful Post:
    firefox (Yesterday)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
