Results 1 to 6 of 6
Thread: Need M101 part
  1. #1
    Private
    Join Date
    May 2019
    Dallas, TX
    Posts
    Default Need M101 part
    Yesterday the casted part that ties the frame, spring and tongue together snapped. The right side, specifically. It is the piece that pivots the dump bed. I have looked through previous threads and I see a couple that pertain, but I do not have the equipment or materials to fabricate a fix. Does anyone have a part or know a resource for same?
    Broken right side in pic 1 and 2.Undamaged left side in pic 3 and 4.
    JD Harrison
    Old School BBQ Texas
    Anna, Tx
    469-371-262620190516_162315.jpg20190516_162256.jpg20190516_162240.jpg20190516_162222.jpg
  2. #2
    4 Star General Steel Soldiers Vendor Evil Dr. Porkchop's Avatar
    Join Date
    Nov 2011
    Colchester, VT
    Posts
    1,825
    700
    Default
    The part number for the right side is 7339405. That's a pretty common problem, since the trailers aren't designed to dump those break sometimes. Hopefully someone parting out a trailer has one for you.
    m151a2, m1028s, m59 dump truck, LCVP, m416, m101a2, m101a3, m104
  3. The Following 2 Users Say Thank You to Evil Dr. Porkchop For This Useful Post:
    McGuyver (05-17-2019), porkysplace (05-17-2019)
  4. #3
    4 Star General porkysplace's Avatar
    Join Date
    Apr 2009
    mid- michigan
    Posts
    8,987
    6,083
    Default
    Yep , they are not designed to dump , the tongue folds to take up less room when shipping.
    Probably should post a want ad in the classifieds , want ads are free .
    Attached Images Attached Images
  5. #4
    General
    Join Date
    Jul 2004
    Utah
    Posts
    455
    96
    Default
    Yeah, there's your problem. A lot a people think these trailers are designed to dump, but they aren't. The axis of the so called pivot bolts are not aligned, so it puts stress on the brackets if you try to pivot the trailer there to dump it. It's probably ok to fold it there for shipping because you can leave the bolts loose and prevent binding, but you can't leave them loose if you try to dump the trailer that way.
    Sent from my SM-G920V using Tapatalk
  6. #5
    Moderator Tinstar's Avatar
    Join Date
    Aug 2013
    Central, Oklahoma
    Posts
    3,434
    903
    Default
    You will have to find a salvage trailer to get that part.
    That part is almost impossible to find, along with the brake levers.
    As already mentioned, the trailer was designed to fold up a bit for transportation on a railroad car.
    It was never, ever designed to dump.
    Sure, guys do it all the time.
    But you've now found out the hard way on “why” they aren’t supposed to dump.
    Post your needs in the Parts Wanted Forum and you might get lucky.
    1987 M1008A1 (2)
    1986 M1009
    1995 NF2D FloodLight/Kohler-Kubota Generator Set
    1992 M101A2 trailer (2)
    S-280 Shelter
  7. #6
    General
    Join Date
    Jul 2004
    Utah
    Posts
    455
    96
    Default
    I wonder if someone could fabricate these brackets out of bent plate...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
