coachgeo
- 3,332
- 113
- North of Cincy OH
putting out a request for anyone to shoot pics or drawings that show location of the grounds on actual truck that fall on and near the bridge behind the cab that the Polarity Protection Box/Air Cleaner/Spare Tire attaches... AND most importantly where they go to from there......The (ground) connections....: ... Polarity Protection Box (PPB), Ground shunt (next to the PPB), PPB to starter, PPB to PDP (Power Distribution Panel) connections, ....
Truck working on was mid project from previous owner and had bridge removed and PPB was just sitting there (still wired too). Thus, I've no clue where the grounds from the bridge ended up getting re-installed at. If I know where the OEM ones on bridge originally were... but especially if knew where they continue on to... can then trace from end point back toward bridge and locate them in their re-located spot. Everything electrical seems to work now so might not move these grounds back to bridge... unless bridge appears it would be a more accessible spot once putting the habitat in place.... yet need to know for future troubleshooting where these grounds ended up.
Any help would be appreciated.
