Stock Top Speed and Oil Pressure for M923/5a2
74M35A2
312
Livonia, MI
Posting for potential buyers of M923/5a2 trucks. I was looking for this info when I was buying, years ago. This is the electric oil pressure gauge replaced by a mechanical one, so better resolution. Just snapped this pic 2 days ago:
dmetalmiki
2,026
London England
You just can't beat mechanical gauges. They read true and are reliable.
All my trucks are so fitted, Both temperature and oil pressure.
Swamp Donkey
The Engineer
118
Gray, GA
So is this just a subtle hint that you did the big cam swap and are no longer double-clutchin' the ol' plunger?
Maybe I read too far between the lines...:mrgreen:
simp5782
Feo, Fuerte y Formal
9,258
Mason, TN
He is trying to compete with me. The only reason his A2 has more power than my truck at the moment is cause mine doesnt have an engine in it. He is trying to be different with the ISL but the KTA will still eat its lunch
74M35A2
312
Livonia, MI
I was going to simply up the power of my 6CTA8.3. Bought a governor spring kit, studied both fuel rate adjustments on the MW pump, bought higher flow injectors with more holes, bought a P pump, drilled and tapped the exhaust manifold for EGT and pressure probes, then before I installed any of it, tripped across a 400hp ISL pulled from a burned RV. It is basically a modernized 8.3L. ISL is 8.9L (stroked 8.3L), 4 valve/cylinder, EFI multi-inject per combustion, VGT turbo, Jake brake, exhaust brake, 2 piece steel topped pistons, etc... The ISL has the highest power per displacement (density) of any Cummins motors. The 6CTA 8.3L seems happy to maybe 300hp or so, but this way grabbed another factory certified 100hp, increased cold start ability, added free cruise control, etc... I have not installed it yet, but I do have it mated to a 13 speed RoadRanger for when it happens.
Also have a Cummins ISX Signature 600 if I was going to compete with anybody.
Steelreaper80
96
Indianapolis IN
You guys are starting to give me the need more power bug! I thought I would be happy after fuel pump mods but now who knows. But then again, I know the higher HP I go the more stuff I will break.
Jbulach
2,046
Sunman Indiana
IMG_7037.jpgGood to know my stock oil pressure gauge is likely close. Our fuel gauges look suspiciously related as well...
