Page 1 of 40 1 2 3 4 5 11 ... LastLast
Results 1 to 10 of 398
Thread: I have joined the Goat herd
  1. #1
    4 Star General combat32's Avatar
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    Thanks
    40
    Default I have joined the Goat herd
    I have agreed to buy Warthogs Goat, will pick it up Thursday. Meanwhile I found a parts Goat close to me that I can get super cheap but it's gonna be a difficult recovery for sure. More to follow when I get my Goat home from Okie City. Here are a couple of pics of the parts truck,
    Attached Images Attached Images
    Tom
  2. The Following 3 Users Say Thank You to combat32 For This Useful Post:
    m38inmaine (06-06-2015), M813rc (06-06-2015), patracy (06-06-2015)
  3. #2
    4 Star General theeDIZ's Avatar
    Join Date
    Apr 2015
    Annapolis MD
    Posts
    1,011
    Thanks
    191
    Default
    Congratulations , looking forward to a build thread !
    69 kaiser m109a3 wo/w
    73 mep-015a
    85 m105a2
  4. #3
    Moderator MWMULES's Avatar
    Join Date
    Sep 2007
    DESOTO, KANSAS
    MVPA
    10023
    Posts
    5,408
    Thanks
    1,434
    Default
    Could not happen to a nicer guy! Looks like you will have hours of fun on the rebuild, Tom!
    HMIC of BEEFCO Industries world wide.
  5. #4
    4 Star General mkcoen's Avatar
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    Thanks
    967
    Default
    Warthog's looks like a lot less work than the parts Goat
    I can't say enough about how much easier the steering is in mine after switching to the JD Cornhead grease. Plus the fact the steering box doesn't leak now.
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
    US ARMY - Overlanding since 1775
  6. #5
    4 Star General dmetalmiki's Avatar
    Join Date
    Aug 2006
    London England
    Posts
    4,586
    Thanks
    592
    Default
    Wish you luck and all positive vibes in the completion of you recovery and acquisition. We have molly grease in our steering box, no leaks and good steering.
    DIAMOND T M20.
    M54A2 I.H. M62. wrecker
    M54A2 5 Ton (with Praga command station surveillance body fitted)
    M45 530C TFFT fire truck
    1942 Ford Jeep (with underfloor tulsa winch)
    1945 Willys Jeep (with V8 flathead Engine) And overdrive.
    Packard Staff car. (WW11. General Pattern Tribute).
    Ural Military Motorcycle.
    Ex Army Hyster 4 ton Fork lift.
    Onan 7.5 kw ex army generator.
  7. #6
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    Thanks
    40
    Default
    Thanks for the advice on the steering box!
    Tom
  8. #7
    4 Star General frank8003's Avatar
    Join Date
    May 2012
    Ft. Lauderdale, Florida
    Posts
    3,999
    Thanks
    2,813
    Default
    Quote Originally Posted by combat32 View Post
    I was here, had a good time.
  9. The Following 2 Users Say Thank You to frank8003 For This Useful Post:
    oddave715 (10-08-2015), quarkz (06-13-2015)
  10. #8
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    Thanks
    967
    Default
    So did the new Goat make it home? We need pics!
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
  11. #9
    Join Date
    Dec 2007
    Booneville AR.
    Posts
    1,577
    Thanks
    40
    Default
    Sorry Mark , got it home Thursday evening with no troubles. Joe had it loaded on the trailer when I got there, we threw on the exta goodies and I was off. I stopped a couple of times to check my tie downs but all was good all the way home, long day of driving and of corse the next day at work was another 12 hour day.
    Haven't had much time to mess with her except to get her off the trailer, started some cleanup tonight, so far I have pulled about 60 pounds of oak leaves out of the hull, looks like about 100 to gofound 2 drain plugs down there though!
    Steering is not too bad so there must be something in there still, btw I got the tube of grease thanks again Mark! So far missing a lot of little odds and ends, looks like the previous owner(previous to Joe) was putting in a new motor, got it set in and mostly hooked up and just stopped.
    Tomorrow's first order of bidness is to pull off top cover on the motor and check the rack and injectors to make sure nothing is stuck, the try to roll the motor over to make sure she is not stuck. There is some oil in it and it looks clean so hopefully she will spin.
    Lots of work to be done before I try to run it, will have to drop and clean both tanks, fix wiring that's jacked new oil and such plus replace all the little missing parts, motor looks like a rebuild right out of a can so hoping for the best on that, and of course no tailgate
    More to follow as I have time, this could take a while!
    Tom
  12. #10
    Join Date
    Oct 2008
    Spring Branch, TX
    Posts
    5,541
    Thanks
    967
    Default
    Heard there was an issue with the tailgate but was told I'd need to get the story from the owner. Red River Parts has NOS tailgates for $140 (or close to that). I got mine from them and was very happy with it.
    http://www.redriverparts.com/
    KG5RKO
    1954 M37
    1955 Austin Champ
    1980 M116A2 MEP003
    1995 M105A3
Similar Threads
  1. Possible new member of the herd
    By M923driver in forum M38, M38A1 and M170
    Last Post: 09-10-2012, 08:57
  2. Added another M1009 to the herd
    By Smokinyoda in forum CUCV
    Last Post: 06-16-2011, 19:59
  3. New addition to the herd
    By JB in forum CCKW
    Last Post: 08-07-2010, 20:49
  4. Need to thin the herd a little....
    By TACTICAL6 in forum M37
    Last Post: 01-11-2010, 17:25
  5. My herd of deuces.....
    By dm22630 in forum The Deuce
    Last Post: 08-27-2008, 16:40
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
