Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: A/C addition underway
  1. #1
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
    Default A/C addition underway
    20190605_200926.jpg20190605_200950.jpg20190608_204313.jpg20190609_164655.jpg I had to extend the center of the grill 3" forward to clear the condenser fan. Fabricated and installed bracket for filter/dryer 20190615_145640.jpg20190615_153449.jpg20190615_174558.jpg
    Attached Images Attached Images
  2. The Following 5 Users Say Thank You to WildEd For This Useful Post:
    cattlerepairman (06-10-2019), QUADJEEPER (06-11-2019), runk (06-11-2019), silverstate55 (06-11-2019), Tow4 (07-12-2019)
  3. #2
    4 Star General cattlerepairman's Avatar
    Join Date
    Jul 2007
    NORTH (Canada)
    MVPA
    37751E
    Posts
    1,938
    Thanks
    952
    Default
    That is one neat and clean install!
    Sent from my SM-G950W using Tapatalk
    MVPA member. 1974 M35A2C w/w "Queen Lola", rebuilt LDS-465-1A, "D" turbo, Waterloo Overdrive upgrade. Med towbar, 11.00R20 Goodyear G286, flipped hubs, remote brake fluid reservoir, spin-on filters, bypassed FDC, LED taillights, LED headlights, LED turn signals, WESTACH EGT/boost gauge, AVM lockout hubs, LED convoy light, LED lollipop lights, HMMWV seat on air ride base, M211 dash passenger grab handle, hood lift kit, 24V solargizer/battery minder, ether start kit, flasher module mod, heavy duty dog bone ends, M35A3 aluminium fuel tank.
  4. #3
    Sergeant Major Fatalid's Avatar
    Join Date
    Sep 2017
    Mesa, AZ
    Posts
    105
    Thanks
    32
    Default
    Subbed. Good looking work so far!
  5. #4
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
    Default
    20190611_193412.jpg Grill painted. Time to mount the filter/dryer.
  6. The Following User Says Thank You to WildEd For This Useful Post:
    silverstate55 (06-12-2019)
  7. #5
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
  8. The Following 2 Users Say Thank You to WildEd For This Useful Post:
    cattlerepairman (06-15-2019), silverstate55 (06-19-2019)
  9. #6
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
    Default
  10. The Following User Says Thank You to WildEd For This Useful Post:
  11. #7
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
    Default
    Bad news for me. Reverse, 2nd and 5th gear positions of shifter hit the underdash unit even with supplied brackets maxed out. Options are to offset unit to the passenger side and fabricate brackets, or alter shifter dimensions and angles.
  12. #8
    Potato Peeler Sgt Jiggins's Avatar
    Join Date
    Feb 2019
    Lynchburg, VA
    MVPA
    24241L
    Posts
    153
    Thanks
    389
    Default
    Quote Originally Posted by WildEd View Post
    Dunno if it helps you, but when I ran into this issue with my M37 (shifter encounter the dash after mods), I heated the shift lever up with a torch and bent it just a hare. It took about 5 miles to get used to and then I forgot about it until I read your last post.
    SJ/JD
  13. The Following User Says Thank You to Sgt Jiggins For This Useful Post:
  14. #9
    Private
    Join Date
    Mar 2019
    Corbin,KY/Poynor,TX
    Posts
    22
    Thanks
    Default
    Thanks for the info. That's definitely one of my options.
  15. #10
    4 Star General rustystud's Avatar
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,137
    Thanks
    2,290
    Default
    Good looking install. I used to install A/C units in vehicles when I was in Phoenix AZ.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
