Results 1 to 3 of 3
Thread: bendix plug on generator regulator
  1. #1
    Private
    Join Date
    Jun 2012
    Calico Rock Ar.
    Posts
    Thanks
    Default bendix plug on generator regulator
    Good afternoon everyone. I hate to bother anyone, but I could use a little information if anyone could help me. I have a 1951 M37 that I need to replace the wires in the four pin male bendix plug that connects to the regulator. I have disconnected the plug, removed the screw on rear cap and moved the rubber insert back to expose the wire pins. Can anyone give me advice on how to remove the pins from the connector so I can r&r wires. I am trying to avoid damaging the connector. Many thanks.
  2. #2
    Sergeant Major
    Join Date
    Nov 2015
    tulsa OK
    Posts
    127
    Thanks
    Default
    Aviation pin, extractor and pin installation tool
    M35a3 with 53" tires, love them
  3. #3
    Private
    Join Date
    Jun 2012
    Calico Rock Ar.
    Posts
    Thanks
    Default
    Thank you sue for the info. I will try to find the tool you mentioned. Again, thanks for your reply.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
