Page 3 of 3 FirstFirst 1 2 3
Results 21 to 27 of 27
Thread: MEP-804A 24V Alternator no output and RPM Dropouts While Running
  1. #21
    Chief and Indian 155mm's Avatar
    Join Date
    Oct 2011
    Guymon, OK
    Posts
    872
    365
    Default
    Quote Originally Posted by Zed254 View Post
    From Army TM 9 - 6 1 1 5 - 6 4 3 - 1 0. TMs for 804A here: https://www.steelsoldiers.com/showth...n-the-MEP-804A
    Battery Charging Alternator:
    Manufacturer Hitachi
    Model LR220-24
    Rating 20 amps at 24 VDC
    Protective Fuse 30 amps
    $82 to $103 from a variety of suppliers: Search on model number.
    Looks like mine had an original.
    "Artillery Brings Dignity to What Would Otherwise Be Just A Vulgar Brawl"
    "Happiness Is A Belt-Fed Weapon"
  2. The Following User Says Thank You to 155mm For This Useful Post:
    Zed254 (07-11-2019)
  3. #22
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    6,259
    12,079
    Default
    I think there is two different NSN's, with the same part number. In any case, a non problem.
  4. The Following User Says Thank You to Guyfang For This Useful Post:
    155mm (07-11-2019)
  5. #23
    Join Date
    Oct 2011
    Guymon, OK
    Posts
    872
    365
    Default
    on the fuse it shows 32v, 30amp
  6. The Following User Says Thank You to 155mm For This Useful Post:
    Guyfang (07-11-2019)
  7. #24
    Private mrosalik's Avatar
    Join Date
    May 2019
    Oakland Michigan
    Posts
    15
    Default
    Thanks again. I found it in the Technical Manual on a conversion update to circuit breaker. Now when I go back out I know where this is to look. I can also make sure the 60HZ is selected. I also see that the ammeter uses a real shunt. So I can double check the panel meter on the front for accuracy. It was in the green briefly one day last week and when I put voltmeter on cranking batteries I had 28.4V But in a few seconds the panel meter zeroed out again.
  8. The Following User Says Thank You to mrosalik For This Useful Post:
  9. #25
    Sergeant Macondo's Avatar
    Join Date
    Jul 2015
    Venezuela
    Posts
    73
    31
    Default
    May ask what is TQG means? Sorry to ask.
  10. #26
    Join Date
    Dec 2015
    Posts
    6,259
    12,079
    Default
    Tactical Quite Generator. Why should you hate to ask? The only dumb question, is the question not asked! Thats what we are here for.
  11. The Following 3 Users Say Thank You to Guyfang For This Useful Post:
    Coug (07-12-2019), Macondo (07-13-2019), mcii (07-12-2019)
  12. #27
    Join Date
    Jul 2015
    Venezuela
    Posts
    73
    31
    Default
    Jaja it is true... thanks!
    Quote Originally Posted by Guyfang View Post
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
