Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Starter Drive Grinding Ring Gear
  1. #1
    Private
    Join Date
    Jan 2017
    Los Angeles, CA
    Posts
    Thanks
    Default Starter Drive Grinding Ring Gear
    Good afternoon SS,
    Relatively new to the forum and appreciate the tremendous resource SS provides for HMMWV related questions. A friend suggested I reach out to the community to help diagnose the cause and identify a solution to a grinding starter drive bendix and flex plate ring gear.
    This 2005 M1123 with a professionally installed 6.5TD unexpectedly stopped starting. As luck would have it, it happened in a remote area that left us stranded for hours until a flatbed tow truck arrived. On the bright side, it happened after we completed the 2N47 Cleghorn Ridge trail among a group of trail rigs with helpful friends.
    Ultimately, what would esteemed and knowledgeable SS members do in this situation?
    Grinding "No-start" Video: https://youtu.be/4RcmrerJRmY
    Background info:
    2005 M1123 MAK reset chassis with 4L80e
    6.5TD takeout motor from early 2000's M1113/M1114 professionally installed ~3months ago
    Driven 1,550 miles since picked up (<100 starts)
    24Volt Prestolite starter CAGE Code 0EDY1 (shim thickness TBD)
    Starter bolts are tight with no play
    Zero prior "no-starts" up until this failure (did emit a brief squeak/squeal)
    Based on the video & images, bendix appears to fully extend, but fails to catch on the worn gear teeth
    Current plan:
    1. Replace with new flexplate/flywheel ring gear & bolts (NSN# 2815-01-148-3771)
    2. Replace with new starter drive bendix (NSN# 2920-01-187-1310)
    Questions:
    1. Given that the 6.5TD was professionally installed roughly 3months/1,550 miles ago, what can cause the ring gear and bendix gear to get chewed up this quickly?
    2. What tips, tricks, or pitfalls are involved when moving the transmission rearwards to install the new ring gear & bendix?
    3. What special measurement devices or HMMWV specific tools (if any) are required to align the gear teeth contact?
    4. Does the starter have to be completely removed and disassembled just to replace the bendix?
    5. How does one diagnose other issues that would require a new replacement starter instead?
    6. What mechanic is recommended (ideally in California) to successfully repair this issue?
    Attached Images Attached Images
  2. #2
    2 Star General
    Join Date
    Jun 2004
    San Francisco, Ca.
    Posts
    712
    Thanks
    Default
    Shim is .008 thick. make sure that the nose casting doesn't say something like "no shim". If so don't use a shim. Is the stud at the forward end of the starter properly held in place to the bracket with a nut?
  3. #3
    4 Star General 86humv's Avatar
    Join Date
    Jul 2007
    High Desert ca
    Posts
    1,123
    Thanks
    Default
    As Dilvoy says....its at the motor mount.
    86 hmmwv
    M1102
    M101A2
    Lots a hmmwv parts
  4. #4
    Colonel
    Join Date
    Sep 2013
    California
    Posts
    333
    Thanks
    81
    Default
    Looks like an installation error. Maybe take it back to the professional that installed it (if recently installed)
  5. #5
    4 Star General Retiredwarhorses's Avatar
    Join Date
    Dec 2005
    Brentwood, Calif
    Posts
    2,287
    Thanks
    151
    Default
    Let me chime in here....I did the conversion.
    the starter and all it’s components came on the motor. When a bendix fails, continued operation will chip teeth, as in this scenario. It’s a simple starter change out and flex plate replacement, all done pretty simply while in the truck, have done many. The OP contacted me and I sent him links to new, NOS and very nice takeout starters.
    while the bendix can be changed out, the time it takes and experience to set the lash correctly on the bench is not always for the shade tree mechanic. I’ve done several bendix replacements, the labor hours to change it make no sense
    to fix it, starters are quite plentiful IMO, I have a stack of them here in the shop.
    As far as shims go, all HMMWV’s use the same shim, there are 2, never is 25yrs have I seen a starter without the thick shim. If it was wrong to start with, there would have been grinding sound at most if not all start ups.
    i just had a truck in the shop that had a “Tinging noise while running” had been to multiple shops, 1 min under the truck revealed the bendix was “floating” outward on the shaft after startup and pinging off the flex plate.
    Inspected all flex plate teeth for missing or damaged and starter was replaced...problem solved.
    Retired War Horses Restoration
    "Where HMMWV's is All We Do"
    A Veteran owned business
    www.RetiredWarHorses.com
    So many HMMWVs I lost count years ago....
  6. The Following User Says Thank You to Retiredwarhorses For This Useful Post:
    TOBASH (07-11-2019)
  7. #6
    Join Date
    Dec 2005
    Brentwood, Calif
    Posts
    2,287
    Thanks
    151
    Default
    Quote Originally Posted by 86humv View Post
    All late model A2 and Turbo motors have the “Hook style” front support....if I do a starter on an A0/A1’s truck, I Install the new style bracket, makes installing the starter a breeze compared to the old style.
  8. The Following User Says Thank You to Retiredwarhorses For This Useful Post:
    TOBASH (07-11-2019)
  9. #7
    Private
    Join Date
    Jan 2017
    Los Angeles, CA
    Posts
    Thanks
    Default
    @Dilvoy & @86humv - thanks for the input.
    @Retiredwarhorses - appreciate the feedback about replacing both the flexplate & starter. With all the parts on hand, how many hours would it take to replace them?
  10. #8
    Colonel
    Join Date
    Sep 2013
    California
    Posts
    333
    Thanks
    81
    Default
    Im having similar problems (occasional grind) on mine. Looking forward to the final resolution on this one.
  11. #9
    Join Date
    Dec 2005
    Brentwood, Calif
    Posts
    2,287
    Thanks
    151
    Default
    Quote Originally Posted by RustyM923 View Post
    I’m having similar problems (occasional grind) on mine. Looking forward to the final resolution on this one.
    Check the flex plate for missing teeth, if it just try’s to engage at times and won’t, “not grinding” that’s a bad bendix or weak solenoid, not enough power to shoot the bendix out far enough to engage the flex plate.
    simplest solution is to just replace the starter...
  12. #10
    Private
    Join Date
    Jan 2017
    Los Angeles, CA
    Posts
    Thanks
    Default
    @Retiredwarhorses - appreciate the feedback. With all the parts on hand, how many hours would it take to replace the flexplate & starter?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
