- 4,208
- 2,876
- 113
- Fort Worth, Texas
I swapped out the fuel pump and bled each injector. Crank and fire! The fuel pressure gauge shows 20psi on the secondary filter. There's no lack of power when I drove it around my yard. The radiator was bone dry and the engine oil has water contamination so the next step is to do services and see if those are related problems. DRMO likes to drain coolant and what do you expect to engine oil to look like after sitting for 14 years.. I may just be paranoid but I'd rather be sure.
https://youtu.be/fnROLaOscwQ
https://youtu.be/Zr4OINI6Rc0
