Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: M151 engine head differences?
  1. #1
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    34
    Thanks
    Default M151 engine head differences?
    Hello everyone I trying to find some information as to the key characteristics between the Light duty and Heavy duty engine heads the the M151s. I was advised that I have an early head and if it requires too much work then to replace with a Heavy duty head. I believe my A2 is an early AMG and the next question is when did the Heavy duty heads start being produced?
  2. #2
    4 Star General nattieleather's Avatar
    Join Date
    May 2007
    Cleveland, OH
    Posts
    1,766
    Thanks
    141
    Default
    I am not aware that there was a light and heavy duty head. As far as I know the heads were the same on all M151s from start to end. I've used heads off of A1 motors on A2s and vice versa. Please if someone has more information please share but as I said I don't know of any difference of light duty vrs heavy duty.
  3. The Following User Says Thank You to nattieleather For This Useful Post:
    USAFSS-ColdWarrior (07-13-2019)
  4. #3
    Sergeant
    Join Date
    Jun 2017
    Berlin, Maryland
    Posts
    62
    Thanks
    Default
    I’ve always heard that all a2 heads had heavier duty valve seats than a1 heads, but I don’t know for sure if that’s true
  5. The Following User Says Thank You to CBrinker For This Useful Post:
  6. #4
    Private
    Join Date
    Jun 2012
    Falmouth, Massachusetts
    Posts
    13
    Thanks
    Default
    The heavy duty head was introduced as a retro fit to any 151 .
    as was mentioned they have hardened valve seats.
    The other improvement was a
    much larger boss that holds the exhaust manifold.
    typically an improved gasket is used to seal the exhaust manifold not just moly grease.
    Fil Bonica
  7. The Following 3 Users Say Thank You to FilBonica For This Useful Post:
    B3.3T (07-15-2019), USAFSS-ColdWarrior (07-13-2019), WIZ87 (07-17-2019)
  8. #5
    Join Date
    May 2007
    Cleveland, OH
    Posts
    1,766
    Thanks
    141
    Default
    I know that at one time a kit was available for the exhaust manifold which had four square gaskets made out of a fiber metal material, new clamps and bolts and this kit solved exhaust leaks at the manifold, but how knows if any still are available today.
  9. The Following 2 Users Say Thank You to nattieleather For This Useful Post:
    microjeep (07-14-2019), USAFSS-ColdWarrior (07-15-2019)
  10. #6
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    34
    Thanks
    Default
    Awesome thank you for the responses. I have an A2 that I am refurbishing. Have the early head and it just received a check and valve job. If it flunked I was going to get the updated head.
  11. The Following User Says Thank You to WIZ87 For This Useful Post:
    USAFSS-ColdWarrior (07-17-2019)
  12. #7
    Private
    Join Date
    Jun 2012
    Posts
    13
    Thanks
    Default
    If you refurbished the head then you should be all set.
    Fil Bonica
  13. The Following User Says Thank You to FilBonica For This Useful Post:
  14. #8
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    34
    Thanks
    Default
    I have seen the exhaust kits similar to your description nattieleather on ARMYJEEPPARTS.COM the picture shows square gaskets for the exhaust manifold. I did read a thread on G838 referring to the different torque specs between gasket and non gasket set ups. Another user did mention the doubling up intake manifold gaskets to make up the difference made by the exhaust gaskets. I'll see if I can find the link.
  15. The Following User Says Thank You to WIZ87 For This Useful Post:
  16. #9
    Private
    Join Date
    Jun 2012
    Posts
    13
    Thanks
    Default
    I mentioned doubling up the intake gasket.
    someone told me but I never tried it .
    all my heads were late style so no need.
    apparent the saddle size is just a bit snaller.
    Fil Bonica
  17. The Following User Says Thank You to FilBonica For This Useful Post:
  18. #10
    Corporal
    Join Date
    Oct 2017
    North East Ohio
    Posts
    34
    Thanks
    Default
  19. The Following User Says Thank You to WIZ87 For This Useful Post:
    USAFSS-ColdWarrior (07-18-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
