Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
Thread: things you dont want to see inside your hydrovac
  1. #11
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default
    Quote Originally Posted by Floridianson View Post
    No just parts. Yea can look and see if I still have a long pack and yes on the spring. I will go to the farm tomorrow and look sea.
    thanks, can you see if this is the right setup ? the only parts i'm not so sure off is the cup where the springs are sitting in and the rubber seal in front of it, because when turning the housing everything just slided out....offcourse…
    Attached Images Attached Images
    m416 cargo trailer 2*
    m416 generator trailer
    m116 trailer
    Chevy blazer s10 1988
    bombardier iltis 1983
    jeep m38a1 (cj5M) 1961
    Reo m275 1968
  2. #12
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default
    I added a small water trap on my air pack feed line. I might have a couple of air packs for parts if you need.
    hi sir, did you found a good spring ?
    m116 trailer
    Reo m275 1968
  3. #13
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default piston rod
    almost done, did take apart the piston rod , cleaned and put back together with new seal, now waiting for the honing tool to give the cilinder where the piston is sitting a nice and smooth inner wall again, meanwhile i will clean out the airlines on the truck...when draining the air tanks besides a bit moisture there's also some black stuff coming with it, what looks like oil…..is it possible that the engine oil used for lubricating the pump is forced into the airlines somehow?
    m116 trailer
    Reo m275 1968
  4. #14
    Corporal
    Join Date
    Mar 2018
    Riverhead, NY
    Posts
    36
    Thanks
    17
    Default
    I am not certain but it seems likely. I notice the same thing from the tanks on my truck and the compressor is lubed from the engine oil supply so any blow by will end up in the air system.
    This is true even with industrial compressed air systems and the water and oil is often removed thru the use of filters and dryers. The deuce does not have either of these standard to my knowledge.
  5. #15
    4 Star General Floridianson's Avatar
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,950
    Thanks
    2,696
    Default
    I have a whole take out and don't know what shape it's in. Shipping the whole thing would bet is high. I can open it up if you just want the spring or any other small parts just pay shipping.
    James
  6. The Following 2 Users Say Thank You to Floridianson For This Useful Post:
    johan77 (07-20-2019), marchplumber (07-21-2019)
  7. #16
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default
    thank you sir, with the spring (if in fairly god condition ) i would be already very happy
    m116 trailer
    Reo m275 1968
  8. #17
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,950
    Thanks
    2,696
    Default
    Glad you did not want the whole thing. I don't remember taking this apart but some of the nuts were loose. Then no spring inside! I think I have one or two more air packs for parts and will look sea Monday. Sorry.
    James
  9. The Following User Says Thank You to Floridianson For This Useful Post:
  10. #18
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default
    thanks, no problem, still 2 more chances
    m116 trailer
    Reo m275 1968
  11. #19
    Sergeant
    Join Date
    Dec 2013
    limburg belgium
    Posts
    88
    Thanks
    42
    Default
    however….the big spring, should it be there ? accidently i came up with a rebuild kit for the short style airpack and there i've seen is a large spring included but i'm not sure about the size of that one...so now i'm wondering if the long style airpack should have a spring inside there ? maybe a stupid question, just wondering....??
    m116 trailer
    Reo m275 1968
  12. #20
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,950
    Thanks
    2,696
    Default
    Sorry found one short pack and one 5 ton air pack in the parts trailer. Could not find the spring that came off the long pack so no spring from me.
    James
  13. The Following User Says Thank You to Floridianson For This Useful Post:
    johan77 (07-22-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
