Clean out fuel tank
aztec
dunnellon florida
Fuel tank all gunned up what works to clean out sticky sludge inside 931-a2
will have to do both tanks removed pickup tube it was clogged up
simp5782
Feo, Fuerte y Formal
9,248
Mason, TN
About 10 or 15 gal of vinegar and fill it with the rest of the way with water and let it sit is what I do. I let it sit a day or two.
You can also just wash it out. It is a stainless tank so it wont rust with water. When you refill with fuel you should add some type of algae eats or preventer from Powerserv, Lucas, or howe's
Wash as much out with nozzle on a hose before filling it with vinegar/water
74M35A2
311
Livonia, MI
Remove tank. Fill with few gallons of E85 fuel (alcohol) and a few shovels of pea gravel. Roll tank around. Will look clean enough to perform open heart surgery when done.
av8or
fort denaud, florida
The E 85 will thin the gum, drain, repeat, spray out with more E 85 through a siphon spray gun and a long piece of brake line to reach back corners to avoid tank removal.
