Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
Results 21 to 30 of 80
Thread: Newbie with an -803a
  1. #21
    4 Star General Light in the Dark's Avatar
    Join Date
    Aug 2016
    MA
    Posts
    1,463
    Thanks
    1,281
    Default
    I think the castle nut on these takes a 1.5" socket if memory serves. That looks much larger.
  2. The Following User Says Thank You to Light in the Dark For This Useful Post:
    76shovel (07-22-2019)
  3. #22
    2 Star Admiral Daybreak's Avatar
    Join Date
    Mar 2015
    Northern, Virginia
    Posts
    1,230
    Thanks
    200
    Default
    Howdy,
    Do NOT use ATF fluid in your unit just yet. If your unit was reset, and does not have tons of hours on it. It probably is not junked up. I say change the oil because oil breaks down after years of sitting after it has been used, heated, cooled, and heated and cooled. You said it was reset in 2005. That's a long time for oil to break down. If later you find you have oil system issues, then you can think about running some ATF fluid in the crankcase for a run and then empty.
    needed
    1 spin on oil filter
    1 spin on water fuel filter
    1 cartridge filter
    That's the way they are. there is not changing. The 002 and 003 are units which folks have modded to spin-on filters.
    Go back to the Filters thread, 2nd post and go through the quick links again. You will then be up to speed with the naming of accessories too.
    ~~Later Mike
  4. The Following 3 Users Say Thank You to Daybreak For This Useful Post:
    76shovel (07-22-2019), Guyfang (07-22-2019), Light in the Dark (07-22-2019)
  5. #23
    4 Star General Guyfang's Avatar
    Join Date
    Dec 2015
    Burgkunstadt, Germany
    Posts
    5,853
    Thanks
    10,654
    Default
    Quote Originally Posted by Light in the Dark View Post
    If you are intending on doing a flush, I believe I have previously read here a post from Guyfang about running ATF in the machine instead of oil for a certain amount of hours. Really helps strip out any built up gunk, then flush, and replace with standard oil. Maybe he will wander by to correct me.
    Dude! You beat me to the draw again!
    Yes, you can do the ATF thing. Run it 1/2 to 3/4 hour. I would use the old filter. Then some cheapo oil and a filter, run it for 2 hours. Then change it with good oil and filter.
    You can also take a look at the old filter first. You can tip the set up, and the oil will drain away from the oil filter. Then unscrew it. pour out some of the oil from the filter into a glass. If its not funky, then simply put the filter back on, run the set to warm it up and change the oil.
    There are some hard to get at places on the set. Shine a light into them. See a lot of fine sand and grit? The set has been down range. Look for that kind of thing. it can help you decide how far into it you want to go. The old rule of, "If it aint broke, don't fix it" is as good today, as it was 100 years ago.
    Edit,
    Ahhhhhhhhhhhhhh. I missed it being a reset! Then Daybreak is right. Don't need the ATF. But yes, do change all POL products and filters.
  6. The Following 2 Users Say Thank You to Guyfang For This Useful Post:
    76shovel (07-22-2019), Light in the Dark (07-22-2019)
  7. #24
    Join Date
    Dec 2015
    Posts
    5,853
    Thanks
    10,654
    Default
    Quote Originally Posted by 76shovel View Post
    Attachment 771186
    can someone help me identify some of these items
    Tent stakes, ground wire for either the trailer or skid unit, some kind of socket maybe, can't tell if that's a fuel tank cap in the upper corner or not, and maybe some grounding rods or maybe fuel cap rods
    The rubber thing is a battery terminal cover. I kinda like them on the POS. terminal. The big socket? trailer Lunet nut? Cant see whats all the way in the back.
  8. The Following 2 Users Say Thank You to Guyfang For This Useful Post:
  9. #25
    Corporal
    Join Date
    Jul 2019
    Bunnell/FL
    Posts
    49
    Thanks
    Default
    2082798_6462_11860_0001.jpg2082798_6462_11920_0001.jpg2082798_6462_0_0001.jpg2082798_6462_0_0004.jpg2082798_6463_414_0001.jpg
    I figured I would post some pics of the unit...Guyfang in some of the pics you can see some build up of dust/dirt along with some cob webs. So im sure a good cleaning will be in order. The hr meter reads 587 which isn't much in 14yrs since the reset. I guess it can be a bad thing or good. Time will tell soon enough I guess. Thank you for all the comments about my box of collected junk...I was hoping for a treasure chest but got a trunk full of junk...lol...I'm sure the ground wire will be usefully if anything
  10. The Following 3 Users Say Thank You to 76shovel For This Useful Post:
    Another Ahab (07-22-2019), Guyfang (07-23-2019), Light in the Dark (07-22-2019)
  11. #26
    Join Date
    Aug 2016
    MA
    Posts
    1,463
    Thanks
    1,281
    Default
    Quote Originally Posted by Daybreak View Post
    Howdy,
    needed
    1 cartridge filter
    I missed the mention of the reset, my bad.
  12. #27
    General robson1015's Avatar
    Join Date
    Oct 2013
    New Concord, Ohio
    Posts
    401
    Thanks
    120
    Default
    Fuel return lines will need replaced for sure....check the infamous well nuts also. Good luck with your new addiction....
  13. The Following 2 Users Say Thank You to robson1015 For This Useful Post:
  14. #28
    General
    Join Date
    Dec 2017
    Green OH
    Posts
    418
    Thanks
    79
    Default
    Looks like a pretty clean unit!
  15. #29
    Corporal
    Join Date
    Jul 2019
    Bunnell/FL
    Posts
    49
    Thanks
    Default
    If that's the case. Lets hope it runs as good as it looks...of course without spending a ton of money on it
    With that being said does anyone care to share how much they spent getting the're generator up and running to a reliable state. Im budgeting 500.00...now am i in a dream? And please don't laugh if I'm way off...lol
  16. The Following User Says Thank You to 76shovel For This Useful Post:
    Another Ahab (07-24-2019)
  17. #30
    4 Star General Another Ahab's Avatar
    Join Date
    Jan 2012
    Alexandria, VA
    Posts
    15,178
    Thanks
    22,067
    Default
    Like anything, it's a moving target, but maybe there's a rule-of-thumb someone will quote you here.
    If you do hear any laughing, it's nobody laughing at you, it's just laughing for the fun of it.
    Because it's fun, you know, horsing around:
    M35A2 w/Winch SOLD
  18. The Following User Says Thank You to Another Ahab For This Useful Post:
    Guyfang (07-24-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
