Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Intermittent Alt 1 light
  1. #11
    2 Star General
    Join Date
    Jul 2017
    Crystal City Mo
    Posts
    711
    Thanks
    1,769
    Default
    Matt S Have you checked out the CUCV Helpful Threads?
    Lots of great information. There is a member here that has a lot of the rebuild parts.
    His handle will come up, if I can remember.
    Belt Fed Multi Barrel Motor Motivated
    Help From Above
    GAU 8 See You Next Time
  2. #12
    Sergeant Matt S's Avatar
    Join Date
    Oct 2017
    Los Angeles, CA
    Posts
    81
    Thanks
    26
    Default
    Quote Originally Posted by cucvmule View Post
    Yes I have. The links to the kits don't work. The other links lead to multiple kits. Tow4 is the member I PM'd over a month ago and haven't heard back from.
    Which kit/parts are necessary?
    1986 M1031
  3. #13
    Join Date
    Oct 2017
    Los Angeles, CA
    Posts
    81
    Thanks
    26
    Default
    Update - I've contacted 2 vendors. Kits look similar but one includes the hardware and other one does not. I'm placing an order and I'll update with the results.
    1986 M1031
  4. The Following User Says Thank You to Matt S For This Useful Post:
    n8roro (10-22-2019)
  5. #14
    4 Star General Tow4's Avatar
    Join Date
    Dec 2009
    Orlando, FL
    Posts
    1,807
    Thanks
    2,438
    Default
    Quote Originally Posted by Matt S View Post
    Sorry I missed your pm Matt. I had replied to several inquiries and thought I got all of them. I'm not offering the kits at this time. I may in the future and will post another classified ad at that time.
    Ray
    1970 M35A2 Sold
    1972 M818 Sold
    1984 M1028A2 W/S250 Shelter
    1985 M929
    1984 M915A1
    1985 M373A2
    CUCV Alternator Rebuild Thread:
    http://www.steelsoldiers.com/showthr...rnator-Rebuild
  6. #15
    Join Date
    Oct 2017
    Los Angeles, CA
    Posts
    81
    Thanks
    26
    Default
    Well...It was going well and then the rear bearing didn't want to come out and the housing is toast.
    Now I'm looking for a new one. I hate it when I do that.
    1986 M1031
  7. #16
    4 Star General
    Join Date
    Sep 2008
    Tisbury, Massachusetts
    Posts
    1,549
    Thanks
    146
    Default
    When I "rebuild" my alts, I usually do not replace the bearings if they seem tight and are running quiet. Usually they are not the problem, especially on relatively low mile CUCVs and the OEM ones are probably better than the reproductions.
  8. #17
    4 Star General Barrman's Avatar
    Join Date
    Dec 2005
    Giddings, Texas
    Posts
    4,315
    Thanks
    Default
    It reads like you have a broken foot, need to drive your CUCV to work and now it can't be driven because your alternator rear housing is broken. Correct?
    Put your passenger side alternator on the drivers side, wire it up and isolate the wires that went to the passenger side alternator so they don't touch anything. You are in California where you won't have to do repeated super cold starts. You can get 10-15 starts on good batteries without working alternators. Get yourself to work and back and then charge the rear battery at home each night. This will let you get along until you find another Delco 27Si alternator housing.
    "If you didn't build it, you can't call it yours."
    1952 M35 W/W Gasser
    1953 M35 W/W Gasser
    1967 M715 6.2/NV4500
    1967 M416
    1971 M35A2 Whistler W/W
    1985 M1009
    1985 M1009
    1985 M1009
    1985 M1009
    1985 M1009
    1986 M105A3
    1987 M1007 Suburban (Cowdog)
    1988 M105A3
    1990 M101A2
    1991 M101A2
  9. The Following 2 Users Say Thank You to Barrman For This Useful Post:
    Matt S (10-29-2019), royalflush55 (10-29-2019)
  10. #18
    Join Date
    Oct 2017
    Los Angeles, CA
    Posts
    81
    Thanks
    26
    Default
    Quote Originally Posted by Barrman View Post
    Awesome and thoughtful response! The foot has healed enough to get back on the motorcycle. That's a great way to get by that I wasn't aware of. The new alternator should arrive this week and I could be back up and running this weekend.
    1986 M1031
  11. #19
    Join Date
    Dec 2005
    Giddings, Texas
    Posts
    4,315
    Thanks
    Default
    Drivers side alternator charges the front battery and keeps the truck running. Passenger side alternator charges the rear battery and is only used for a stock starter motor and stock glow plug system. If your truck starts up like it should. Less than a second of cranking time. Then that back battery doesn't need more than a few minutes of charge before it is topped off again.
    Glad the foot is healed enough to be in the wind again.
    1952 M35 W/W Gasser
    1953 M35 W/W Gasser
    1967 M416
    1985 M1009
    1985 M1009
    1985 M1009
    1985 M1009
    1985 M1009
    1986 M105A3
    1988 M105A3
    1990 M101A2
    1991 M101A2
  12. #20
    Join Date
    Oct 2017
    Los Angeles, CA
    Posts
    81
    Thanks
    26
    Default
    The new alternator is on. The gauge initially went to the high end of the gauge. Might've been since it was catching the battery back up to par. It was charging at 14.48v while Alt 2 was 14.40v. After a drive the gauge has come down a bit. The dash light has been consistently on.
    The new belts are silent. I'm thinking of trying to get another alternator back to get a back up ready.
    1986 M1031
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
