Results 1 to 8 of 8
Thread: Fuel gauge sender
  1. #1
    Sergeant Major
    Join Date
    Apr 2016
    Echuca VIC, Australia
    Posts
    157
    Thanks
    Default Fuel gauge sender
    It would be nice to have a working fuel gauge in the goat. I'm guessing the sender is the likely problem, are they common to any other vehicles?
  2. #2
    Sergeant Major PointnShoot4WD's Avatar
    Join Date
    Nov 2009
    Augusta, Georgia
    Posts
    128
    Thanks
    29
    Default
    Pretty sure they are common to the M151, check the parts list and cross check the NSN and or manufacturers part number to those listed by TNJ or similar.
  3. The Following User Says Thank You to PointnShoot4WD For This Useful Post:
    cucvmule (08-01-2019)
  4. #3
    General
    Join Date
    Jul 2017
    Crystal City Mo
    Posts
    528
    Thanks
    1,389
    Default
    Have you checked out the wire connections to see if it is just a little corrosion, at the tank or it is just the gage itself?
    Belt Fed Multi Barrel Motor Motivated
    Help From Above
    GAU 8 See You Next Time
  5. #4
    Join Date
    Nov 2009
    Augusta, Georgia
    Posts
    128
    Thanks
    29
    Default
    Checked the -20P, for the sender your NSN is 2910-976-5417, manufacturers number 8712134.
    Not common to the Jeep series, although the dash gauge is, seems the M561 unit is longer so a Jeep unit may be adaptable...
    Spock
  6. #5
    Sergeant Major
    Join Date
    Apr 2016
    Posts
    157
    Thanks
    Default
    Jeep as in M715? That would be handy, I'm about to pull the one out of my 715 to fit an aftermarket gauge.
  7. #6
    Sergeant
    Join Date
    Jan 2016
    Colorado Springs, CO
    Posts
    88
    Thanks
    120
    Default
    "Please fairy godmother have him post the info. for the sending unit and correct gauge when he fixes his so I don't have to do any research of my own when I go to fix mine"....if it weren't for everyone else's hard work on their rigs on this site and me using their information I would have two large rusty lawn ornaments instead of tacti-cool vehicles.
  8. #7
    Join Date
    Nov 2009
    Augusta, Georgia
    Posts
    128
    Thanks
    29
    Default
    M38 from what I was reading mate, but it's worth a try with the 715 unit if you've got it out.
  9. #8
    Join Date
    Nov 2009
    Augusta, Georgia
    Posts
    128
    Thanks
    29
    Default
    Quote Originally Posted by SgtMajHarper View Post
    Magical -20P says your numbers for the gauge are 6620-933-3600 and MS24544-2.
    Common M-series and listed under M151 parts as available at TNJ.
    Spock
  10. The Following User Says Thank You to PointnShoot4WD For This Useful Post:
    Aussiecowboy (08-12-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
