Mep-805a- 30kw generator
walkerman
Palm Harbor florida
need help the overspeed and under voltage light stay on and will not run cleaned sensor and still did not work . will a new one help ? do not have part number
anyone in the Clearwater Florida area that works on these need to find someone
Thank you
Tinstar
1,707
Edmond, Oklahoma
Welcome to Steel Soldiers
Have you downloaded the Technical Manual?
Did you search the forums for the same issue?
Issue has most likely been covered before.
Suprman
649
Stratford/Connecticut
The tms are in the section top of the forum page. There are step by step troubleshooting. If you download them and start troubleshooting, and still get stuck, you can at least post how far you got in the process. Making it easier for someone to offer advice.
Guyfang
22,039
Burgkunstadt, Germany
Thank you
Lets start again. Did this gen set ever work right? Is it new to you? Did you reset the fault indicator?
Guyfang
22,039
You have to reset the over speed first, then the fault indicator. Is that how you did it? If not, or if you cant remember, re do it.
Guyfang
22,039
Try this. Reset the fault indicator, and hold it in the reset position. Then start the set. Keep the fault indicator in reset position. Then flip up the battle short switch. THEN let the reset go. Still running?
walkerman
Palm Harbor florida
Thank You I will try it Monday I'm in Florida looking at the weather. I'm in Clearwater Fl and if anyone knows someone near me that works on these generators I would be happy to pay someone to help.
mcii
Wimberley, Texas
also ? DOESN'T THIS SERIES HAVE THE overspeed RESET LOLCATED ON OR WITHIN THE INTERIOR OF THE CONTROL BOX NEXT TO THE 50/60 SELECTOR SWITCH.. DONT THINK JUST PUSHING THE TESTLAMP RESET BUTTON ON THE INDICATOR PANEL ON THE FRONT PANEL WILL ACTUALLY RESET THE OVERSPEED CONDITION.. LET US KNO MAC/MC
walkerman
Palm Harbor florida
Thank You I got the generator running most problem were dirty connections. I need to find out how to make this 3 phase generator to
single phase I watched Matt Verley u-tube on doing a mep-oo4A generator I would like to find out if this is the same
Thank You
Scoobyshep
989
Florida
The 005 is a 12 lead head, so he did a retap to low zigzag. If memory serves the 805 is a 10 lead head and cant be changes the same way.
Guyfang
22,039
Thank You
Ain't gonna happen. You are talking about apples, (MEP-805A), Matt is talking about pears, (MEP-005A).
