Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
Results 61 to 70 of 81
Thread: MTVR RECOVERY from Yermo cali to Georgia
  1. #61
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    2,442
    Default
    Quote Originally Posted by Efituned View Post
    being?
    Egay
    Don't worry about the size difference
  2. #62
    Modertator swbradley1's Avatar
    Join Date
    Jan 2008
    Dayton, OH
    Posts
    13,736
    3,941
    Default
    being?
    Since you are not allowed to post auctions/Craigslist or any of the other sites I'm just guessing that is why no post about which one.
    sw
    Yes, that's an image of my skull.
  3. #63
    Colonel 8madjack's Avatar
    Join Date
    Jun 2016
    Gold country Ca.
    Posts
    344
    207
    Default
    Quote Originally Posted by swbradley1 View Post
    This is one of those rules that doesn't make sense. Particularly when someone is trying to find a part.
    That being said, I assume ebay when someone says "popular auction site"
  4. #64
    Colonel winfred's Avatar
    Join Date
    Mar 2016
    port allen la
    Posts
    346
    39
    Default
    i can't really see the particles on the magnet well enough in the video but if they are flakey im gonna guess you are loosing a bearing race, the surface is damaged and is coming up and being rolled flat by the bearing rollers, the rest of the bearings may or not survive ingesting the metal as it is circulated by the fluid, their races may look pitted slightly by the embedded metal particles, the gearset will likely be fine unless its run till the failed bearing has a major failure and comes apart loosing containment of either the pinion or carrier positioning, then the gears will loose alignment and eat one another.
    i don't have experience with a diff near that large so this is speculation based on upscaling 1/2 and 1 ton diff and transfer case failures
  5. The Following 3 Users Say Thank You to winfred For This Useful Post:
    8madjack (10-12-2019), Elijah95 (10-12-2019), Terracoma (10-12-2019)
  6. #65
    General Elijah95's Avatar
    Join Date
    Feb 2017
    Georgia
    Posts
    559
    162
    Default
    Quote Originally Posted by winfred View Post
    Pretty good observation! I was stressed out about it until I drained all 3 diffs and all 3 had the exact same thing on the drain plugs. After talking to a few people familiar with these trucks they do have lockers and in the manual it clearly states ďDo not engage additional axles while spinning a tire, damage may occurĒ and thatís what we are theorizing has happened. Small chunks of the locker, I inspected the bearings with a snake camera they all look good from what I can see. Iíve changed the fluid and will keep a close eye on temperatures. Probably will run the fluid another 500 miles or more, then drop it and inspect it by running through the centrifuge to see what kind of wear particles are present
    1974 AMG M35a2 Wo/Winch, Spin ons, White LDT & Whistler, G177's, H1 seat, LEDs, previously a Georgia DOT truck
    1990 M923a2, super singles, soft top, fuel turned up
    Wanted: 900 series hard top, RT-524, (1) front ctis wheel valve
  7. The Following User Says Thank You to Elijah95 For This Useful Post:
  8. #66
    Join Date
    Mar 2016
    port allen la
    Posts
    346
    39
    Default
    it is normal for some metal bits on the magnet, ya gotta be able to read them, the small difference in temp at the rear diff could be it's just the last thing to receive airflow under the truck, shiney lube scares me a little though
  9. #67
    Join Date
    Feb 2017
    Georgia
    Posts
    559
    162
    Default
  10. The Following 2 Users Say Thank You to Elijah95 For This Useful Post:
    cattlerepairman (10-16-2019), silverstate55 (10-16-2019)
  11. #68
    Colonel Nomadic's Avatar
    Join Date
    Oct 2016
    Nevada
    Posts
    236
    139
    Default
    Quote Originally Posted by Elijah95 View Post
    Such a good looking MTVR.
    I'm wondering if I'd hit height issues after putting a camper box on the back. What is the distance from the ground to the bed?
  12. #69
    Join Date
    Feb 2017
    Georgia
    Posts
    559
    162
    Default MTVR RECOVERY from Yermo cali to Georgia
    Quote Originally Posted by Nomadic View Post
    Thanks! Iíll measure for you
  13. The Following User Says Thank You to Elijah95 For This Useful Post:
    Nomadic (10-22-2019)
  14. #70
    Join Date
    Feb 2017
    Georgia
    Posts
    559
    162
    Default
    Gave her **** at the Georgia Rally, rebuilt the compressor aftercooler and air dryer; crazy how much of an improvement these trucks are over the 5 tons. I put it through the worst I could for over 100 miles offroad this past week and I couldnít phase it, had some traction issues due to non-op ctis but after I aired down the truck was almost unstoppable. IMG_3155.JPGIMG_3176.JPG
  15. The Following User Says Thank You to Elijah95 For This Useful Post:
    silverstate55 (10-22-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
