Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: Clutch and flywheel questions
  1. #21
    Colonel Slate's Avatar
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    270
    Thanks
    157
    Default
    Another it does look better than the mirror finish it had.IMG_20190813_132544938.jpg
    Sent from my moto z3 using Tapatalk
  2. The Following User Says Thank You to Slate For This Useful Post:
    cattlerepairman (08-13-2019)
  3. #22
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    270
    Thanks
    157
    Default
    Quote Originally Posted by porkysplace View Post
    Did you make the flywheel and crank before you took it Off ?
    The bolt holes only line up 1 way .
    Yes Sir thank you. There is a slight white chalk mark left above one bolt hole. I did read enough to mark it because of the "only one way" it goes back. I also marked the side of the housing so I can make sure the right hole lines up.
  4. #23
    4 Star General Jeepsinker's Avatar
    Join Date
    Aug 2013
    Dry Creek, Louisiana
    Posts
    5,165
    Thanks
    1,167
    Default
    To bypass the density compensator:
    I sink Jeeps... That is all
    1969 Kaiser Jeep M35a2 w/winch (Daily driver, no joke)
    Now a hot rod deuce: 6BT swap in progress, Waterloo overdrive, 2 micron fuel filtration installed, riding on 11.00r20s
    1971 M151A2 w/ ROPS
    3: 87' M35a2c Air Force trucks
    1991 BMY M936a2 wrecker
    2: M1061 flat trailers
    1: Fresh rebuilt and load tested good Mep003a genset
    I do Fort Polk and other recoveries in my state. I can be reached at 337-401-2470
  5. The Following 2 Users Say Thank You to Jeepsinker For This Useful Post:
    frank8003 (08-13-2019), Slate (08-13-2019)
  6. #24
    Join Date
    Aug 2013
    Posts
    5,165
    Thanks
    1,167
    Default
    This may also help.
    1971 M151A2 w/ ROPS
  7. The Following 2 Users Say Thank You to Jeepsinker For This Useful Post:
  8. #25
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    270
    Thanks
    157
    Default
    Quote Originally Posted by doghead View Post
    Is your Fuel Density Compensator bypassed? Have you ever noticed your oil level going up? Or, smelling like diesel?
    Checked oil level today and yes even though I seem to loose quite a bit of oil after running. My oil level is increasing not decreasing. Fuel in oil. Will bypass FDC as soon as new rear main and clutch is installed. Hopefully that is it.
  9. The Following User Says Thank You to Slate For This Useful Post:
    Jeepsinker (08-14-2019)
  10. #26
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    270
    Thanks
    157
    Default
    As I am new to this I need some advice. The bolts to this seal housing came out with almost no force. Meaning they were more or less loose. There was no gasket behind this. Does it need a gasket that is missing or does it go back without. It was done before my time and after military so I have no clue. TM says some have gasket and some don't. Will it leak without?Attachment 773247IMG_20190814_084653669.jpg
  11. #27
    Join Date
    Apr 2019
    Ozona Texas
    MVPA
    MVPA?
    Posts
    270
    Thanks
    157
    Default
    If gasket is needed can I make it out of this?Attachment 773249IMG_20190814_085200134.jpg
  12. #28
    Colonel davidb56's Avatar
    Join Date
    Feb 2019
    Bonners Ferry Idaho
    Posts
    224
    Thanks
    267
    Default
    Quote Originally Posted by Slate View Post
    that looks a little on the thick side for a machined surface. Make sure you add a pyrometer when you do your FDC bypass.
  13. The Following 2 Users Say Thank You to davidb56 For This Useful Post:
    Menaces Nemesis (08-14-2019), Slate (08-14-2019)
  14. #29
    Super Moderator gringeltaube's Avatar
    Join Date
    May 2005
    Montevideo/Uruguay
    Posts
    5,756
    Thanks
    1,309
    Default
    ...... Will it leak without? (a gasket) ..................
    YES. And most likely the main reason also, for your oil puddles...
    Both surfaces are machined. Best if you clean everything nice and dry and then use something like Loctite 518, instead of a gasket.
  15. The Following 2 Users Say Thank You to gringeltaube For This Useful Post:
    Jeepsinker (08-15-2019), Menaces Nemesis (08-14-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
