Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Growler
  1. #11
    2 Star General
    Join Date
    Jul 2017
    Crystal City Mo
    Posts
    646
    Thanks
    1,617
    Default
    What is surprising to me is that they are not demilling or crushing the units after the safety problems involved. It would be of interest to give out the information rather than the vehicle being altered and then either improving or making the stability problem worse.
    I would think that their are propriety parts involved in the assembly. After all it was designed for a limited purpose use. As much as the units initial cost was there is a lot of growler parts only involved. The more you make, then the unit cost goes down, as new upgrades are applied then old parts are discarded for the new parts so again the first run units become unserviceable because of no new replacement parts.
    Kind of a catch 22.
    Belt Fed Multi Barrel Motor Motivated
    Help From Above
    GAU 8 See You Next Time
  2. #12
    4 Star General Gunzy's Avatar
    Join Date
    May 2013
    Roy, Utah
    Posts
    1,755
    Thanks
    237
    Default
    http://growlerme.com/images/New_M-11...10-09-2014.pdf This may help in contacting Growler for info. Not sure how helpful they will be considering the controversy involved with these.
    If you have more than one car in your drive way, your a car collector.
    '68 Shelby GT-500
    '75 Bricklin SV1
    '87 M985 HEMTT
    M101/116A3
    '02 M1082
    '14 Ford F150 Tremor (1 of 288 produced)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
