Air Valve- front rear tire R
saratoga
Saratoga Springs NY
I'm having trouble building air pressure in M1089.
After I turn off, I hear hissing from the pictured valve around the bottom gasket. muffled when i cover with hand
is it stuck or do i need to pull lines off and have rebuilt?
NDT
5,828
Camp Wood/LC, TX
Cage the brakes but for heavens sake not if there are any grades or on public roads.
saratoga
Saratoga Springs NY
caged when i towed from govplanet. level grade on property, ill tow with grader
cant figure out why it went out of no where.
local guy came over and told me i was engaging trans and releasing brake in wrong order. could i be doing something wrong?
simp5782
Feo, Fuerte y Formal
9,256
Mason, TN
It's got a rubber diaphragm that went out. The rubber is probably 10yrs old if not older. It just gave out and and started venting. Better than it going out and applying air to the brakes locking them up and not venting. This happens alot on trucks primarily used offroad. Junk can get under the flap and cause issues
NDT
5,828
Camp Wood/LC, TX
The order of brake release/ putting in gear has nothing to do with anything. Simp is right, these parts are old and used low quality non-milspec commercial components to begin with.
simp5782
9,256
Mason, TN
Haldex # N50004D or E. Just google or ebay search. Really any R12 valve would work but you may have to have bushings to adapt to the port size fittings you currently have
simp5782
9,256
Mason, TN
They are just JIC on the big hoses they will just swivel right off. The 2 or 3 dot fittings should come right off as well.
simp5782
9,256
Mason, TN
Your old one should have a tag on it. If it does not then post a pic of the valve and how many ports say Del, serv, sup.
It is an R12 valve more than likely i doubt its an R8 . They can have a few various forms of look but serve the same purpose
simp5782
9,256
Mason, TN
Also take a pic of a more general location on the truck. I see another relay valve in the background behind it. Relay valves are usually on each axle set
BRob18E
Liberty Township, OHIO
**** Wes, I must say, the more I read on this site the more I respect your knowledge. You sound like me, I'll dig into anything, but you have tons of experience with all the military vehicles and your knowledge helps many. Keep up the good work.
