Results 1 to 1 of 1
Thread: WMO will not work in the newer diesel RV heaters
  1. #1
    General Reworked LMTV's Avatar
    Join Date
    Nov 2016
    TN
    Posts
    417
    Thanks
    240
    Default WMO will not work in the newer diesel RV heaters
    FYI
    I have been experimenting with WMO to fire this type of heater. This things are very sensitive to flashpoints and don't like anything other than diesel. It won't stay lit. Problem is likely related to the fact that there no compression, as in a diesel engine. Might work at 50/50 wmo and gasoline, but at some point it is just not worth it. https://proxy.duckduckgo.com/iu/?u=h...jpg&f=1&nofb=1
    Remember that tiny cut you forgot about? Brake cleaner remembers.....
  2. The Following 2 Users Say Thank You to Reworked LMTV For This Useful Post:
    98G (09-09-2019), USAFSS-ColdWarrior (09-08-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
