Lonnie
- 18
- 18
- Pittsburgh, PA
My truck has been sitting for for over a year.
I started building a new garage a while ago so the truck got ignored, but at least it got heated indoor storage.
This spring, I started back on the truck.... it needed a radiator, so while apart, I put in a new water pump, all belts hoses etc. Also put in fresh oil & filter.
Fast forward to today when got everything buttoned up & finally I started it (keep in mind I haven't heard it run for a year) & it has a loud knock.
The sound seems to come from the air compressor or that vicinity. I can feel it in the compressor & hear it through the radiator/dr side the loudest. I physically put my ear to the rocker covers & do not hear it.
It is impossible to isolate, as without it the injector pump does not turn so I can't run the engine.
Any ideas or possible issue with the accessory drive that could cause this?
Any advice is appreciated.
