Results 1 to 4 of 4
Thread: 1951 M-37 generator won't polarize
  1. #1
    Private
    Join Date
    Feb 2019
    Harborcreek, Penna.
    Posts
    Thanks
    Default 1951 M-37 generator won't polarize
    Hi.
    Working on my uncle's '51 M-37. Gen. won't polarize / won't charge. Cleaned the points on all the relays in the regulator, cleaned up and verified ground contact to regulator. Verified continuity in reg-to-gen cable. Found an open noise suppression capacitor in the armature output circuit in the gen -- removed that and replaced with direct wire to the cannon plug. Brushes and commutator look good.
    I'm seeing 24 v from the batteries to the regulator, the reg. is putting 11.5 v or so out to the field but I'm only seeing a puny 5.8 to 6.0 v coming back from the armature. Obviously the cutout relay isn't even close to closing. I've tried repolarizing several times by shorting BAT to FLD (using the terminals in the regulator with the cover removed) both stopped and running and I can't get the gen to flash over, even at about half throttle.
    Is a field of 11.5 v normal? I haven't tried to measure the current being drawn by the field but the ARM voltage drops to less than 1 if I open the FLD circuit so it can't be totally open. I hate to tear the gen down and rewind her only to find out it's not the problem. I also don't really want to go with an electronic reg if I can help it.
    Thoughts?
    Thanks in advance,
    Pete P.
    Harborcreek, Penna.
  2. #2
    General SturmTyger380's Avatar
    Join Date
    Nov 2006
    Easley SC
    Posts
    457
    Thanks
    Default
    I have always done the re-polarizing flash directly to the generator with the reg to gen cable removed.
  3. #3
    Colonel
    Join Date
    Jan 2015
    phoenix,az
    Posts
    321
    Thanks
    19
    Default
    Flashing with regulator connected usually means now dead regulator
    1962 DON DJ3A
    1953 M37
    1950 M38
  4. #4
    Sergeant Major
    Join Date
    Jul 2008
    Elizabethtown, PA
    Posts
    108
    Thanks
    Default
    I had to do it around 8 times to get it to be polarize and start charging. I have no idea why it took so many times.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
