hunting for Allison 1545 front pump
Sgt Jiggins
Potato Peeler
204
Lynchburg, VA
Hello All,
I recently acquired an M35A3. The transmission went out for a rebuild because of the typical 4th/reverse scenario. All is done - with the exception of tracking down a new front pump.
Anybody have any leads on one? I've tried Defeo and Drapco so far with no luck.
Thank you,
SJ
simp5782
Feo, Fuerte y Formal
9,256
Mason, TN
Try transtar. They bought out Daaco Detroit a few years back. Daaco used to be the main torque converter company
Sgt Jiggins
Potato Peeler
204
Lynchburg, VA
Negative with transtar, tkt, defeo, darpco.
2 thoughts:
1)borrow a loaner from someone and get a buddy to machine one.
2)has anybody put either a AT-545 or a MT-643 in the truck instead? Does the truck need that lock up for braking?
Thanks,
SJ
rustystud
2,388
Woodinville, Washington
2 thoughts:
Thanks,
SJ
The lock-up is for fuel mileage only. You can totally use a standard AT540 transmission if you so choose.
You can also try calling "All Automatic" at 1-800-461-6839 .
