Leaky M809 manual fuel shutoff valve
US6x4
2,066
Wenatchee, WA
My fuel shutoff valve has 2 leaks currently since doing the dual fuel mod and loosening up the valve. The big leak around the threads I think I'll thicken up with teflon tape if those are pipe threads and if they're straight then maybe a new o-ring is in order. The leak at the shaft has me a little more concerned because I have not seen one of these disassembled and my valve doesn't look like the other ones I've seen so I don't know what's inside. I'm assuming that there is a little o-ring on the shaft that can be replaced? Has anyone seen an exploded diagram of just this valve?
2,391
They can be repaired, just make sure the o rings you get are viton or something else that ULSD won't attack
US6x4
2,066
Wenatchee, WA
doghead, thanks for the link. It seems those valve are made of gold for what they want for them. Isn't it just a ball valve?
I like the repair option the most so I will tear into it soon and replace whatever o-rings and seals I find.
US6x4
2,066
Wenatchee, WA
I disassembled my valve and here is what it looks like all exploded out.
I really hope that the black chunks are not remnants of some seal but rather just sediment build up that took the shape of the inner valve cavity. It crumbles real easy like carbon from a combustion chamber.
US6x4
2,066
Wenatchee, WA
A new standard size -010 o-ring fixed the little leak and some teflon tape and an end wrench fixed the big leak.
