Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Can the turn signal connector be re-wired?
  1. #1
    4 Star General JCKnife's Avatar
    Join Date
    Sep 2009
    Kentucky
    Posts
    1,336
    Thanks
    59
    Default Can the turn signal connector be re-wired?
    M35A2 turn signal connector, I have 2 but both in pretty rough shape. Can they be disassembled and re-wired? I donít see how...
  2. #2
    Sergeant Major
    Join Date
    Nov 2015
    tulsa OK
    Posts
    164
    Thanks
    9
    Default
    Aviation pin tools and probes for cannon plugs,
    thats what you can rebuild it with.
    M35a3 with 53" tires, love them
  3. #3
    Join Date
    Sep 2009
    Kentucky
    Posts
    1,336
    Thanks
    59
    Default
    Sounds like a “no” for most people then.
  4. #4
    Sergeant Major
    Join Date
    Nov 2015
    tulsa OK
    Posts
    164
    Thanks
    9
    Default
    Take it down to the local airport and
    find out who does avionics installations
    and offer them a case of beer and see
    if you get any takers. It’s a very
    common aviation part.
  5. #5
    Sergeant Major
    Join Date
    Nov 2015
    tulsa OK
    Posts
    164
    Thanks
    9
    Default
    Where at in ky are you? We were just
    up there last week.
  6. #6
    dumpsterlandingfromorbit! gimpyrobb's Avatar
    Join Date
    Dec 2005
    Cincy Ohio
    Posts
    27,614
    Thanks
    2,442
    Default
    Jo, I have a kit for wires you can use. Should have the tools to take it apart if you want. Or I could just send the tools
  7. #7
    Super Moderator gringeltaube's Avatar
    Join Date
    May 2005
    Montevideo/Uruguay
    Posts
    5,810
    Thanks
    1,336
    Default
    Quote Originally Posted by JCKnife View Post
    Sounds like a ďnoĒ for most people then.
    ... but it's definitely a "YES" for someone capable of rebuilding his winches...
    Probably easiest if you had those special tools, although it can be done without them. You just need a soldering iron, tiny screwdriver, needle-nose pliers, some silicone grease and lots of patience...
  8. #8
    Join Date
    Sep 2009
    Kentucky
    Posts
    1,336
    Thanks
    59
    Default
    Thanks guys. Let me figure out if the wires are the problem first. My interior turn signal indicator light has quit working, but the bulb is good. I'm thinking maybe it's the solid-state flasher inside the fender?
  9. #9
    4 Star General jasonjc's Avatar
    Join Date
    Apr 2005
    Gravette Ar.
    Posts
    5,171
    Thanks
    1,129
    Default
    There is a good write up on here on making your own flasher using a common 24 volt flasher.
    "It is a proven fact that you cannot idiot proof anything due to Mother Nature's ability to constantly upgrade the common idiot." WM
  10. #10
    Colonel pjwest03's Avatar
    Join Date
    Jul 2015
    Vestal/NY
    Posts
    251
    Thanks
    142
    Default
    Quote Originally Posted by jasonjc View Post
    https://www.steelsoldiers.com/showth...version-how-to
    The two most common elements in the universe are hydrogen and stupidity.
    -- Harlan Ellison
    Now, if we could only harness the power stupidity...
    1969 Kaiser M36A2 WO/W
    MEP-802A
  11. The Following User Says Thank You to pjwest03 For This Useful Post:
    TOBASH (10-07-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
