Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Lighter springs on a 939?
  1. #11
    4 Star General Buffalobwana's Avatar
    Join Date
    Apr 2016
    Frisco Texas
    Posts
    1,288
    274
    Default
    Quote Originally Posted by snowtrac nome View Post
    if you want flex get rid of the short springs leave the longer ones in, generally spacers in the front aren't recommended I have seen some commercial rigs set up that way from the factory.
    The only reason I’d use chopped down springs as spacers, is to maintain ride height. Heat isn’t a springs best friend, but if it’s a shorty, used as a spacer, with no flex, Im guessing it would be fine.
    Hunter, fisherman, international man of intrigue.
    M923A2 camo
    M923A2 Tan (for sale)
    M931A2 camo
    M105A2 sold
    Four M101A2 (3 are for sale)
    M1101 green
    M1101 Tan one - for sale
    Two M1082
    S-280 shelter
    Three very nice S-250 shelters - one for sale
    16.00’s and HEMTT rims - for sale
  2. #12
    2 Star General
    Join Date
    Jul 2017
    Crystal City Mo
    Posts
    714
    1,770
    Default
    I do not know which tire size you currently have on the 939 but is it possible to use a tire with a softer sidewall? Just wondering, if you do not plan on transporting heavy weights then maybe a little help in using the tires as a cushion may help.
    Belt Fed Multi Barrel Motor Motivated
    Help From Above
    GAU 8 See You Next Time
  3. #13
    Join Date
    Apr 2016
    Frisco Texas
    Posts
    1,288
    274
    Default
    I have got 16’s on the 923A2. Pretty stiff tire.
    But they sho do look good!
    M923A2 camo
    M931A2 camo
    M105A2 sold
    M1101 green
    Two M1082
    S-280 shelter
  4. #14
    Colonel
    Join Date
    Feb 2006
    Long Island, NY
    Posts
    289
    Default
    Just a thought, if your setting up the truck for overlanding, are you dead set on keeping the truck 3 axles? I had a buddy bob his truck and add a peterbilt rear air ride. That truck floated down the highway. Very nice ride and he was on 16R20s as well. It had a single leaf spring for controlling axle position and the air bags carried the weight. It flexed very well off road and I think it was rated at 21k or 22k load? The suspension was for a single rear axle box truck.
    1991 M923a2
  5. #15
    Join Date
    Apr 2016
    Frisco Texas
    Posts
    1,288
    274
    Default
    Quote Originally Posted by Lukes_deuce View Post
    Yes, I have. You are right, that would solve a big chunk of the ride issue. And it’s a great idea, unless traction is paramount.
    I guess you should never say never to anything, but I’m opposed bc you are removing the benefits of another axle pushing an already heavy truck through sand or mud. You air down tires to gain traction which increases your footprint by how much? 15%? 20%? Three axles is 50% more grip than 2 axles. That’s substantial. The truck is heavier than most of its 4 wheeled adventure vehicle counterparts like the Mog or LMTVs. When they get up to this weight, most have 6 axles.
    I have thought about designs for airbags on the rear. It would limit articulation when aired up, but allow a fair amount of articulation when aired down.
    I saw Wes had a video about installing bags on the rear of a 939, so now I can’t take complete credit for the idea, although, my design varies from his.
    M923A2 camo
    M931A2 camo
    M105A2 sold
    M1101 green
    Two M1082
    S-280 shelter
  6. #16
    4 Star General Csm Davis's Avatar
    Join Date
    Sep 2009
    Hattiesburg, Mississippi
    Posts
    3,988
    1,964
    Default
    The military actually made air ride rear 939's and profo has air bags up front. I am going all air ride with my XLWB 932A2. I am doing front, rear, cab, seats, and trailer already has rear air ride, and air ride king pin.
    Sent from my SM-G930V using Tapatalk
    Jeff Davis
    SGM G-4 NCOIC Mississippi State Guard
    (601)264-3453
    M931A2 2012 Camp Shelby rebuild
    M928A2
    M927A1 USMC ISO BED
    M927
    M923A2 WAR WAGON GUN TRUCK
    M816/936 Half Breed
    M1028/31 Combat Vet
    M1028 Phoenix
    M1010
    2-M1008's
    4-M1009's
    XM971 TRAILER Mobile HQ
    M129A4 Desert Storm Memorial
    M295a1
    MEP-002A
    2-MEP-003A
    MEP-006
    M101A2/3
    M1101
    M116A2
    M116A3/tool trailer
  7. #17
    Join Date
    Apr 2016
    Frisco Texas
    Posts
    1,288
    274
    Default
    Quote Originally Posted by Csm Davis View Post
    That sounds like something I need to see.
    Can the cab be put on bags in the back (with necessary modifications) using the front mounts to pivot off of? Do you have to raise the front of the cab a bit? I assume they have little shocks to dampen the bounce? Where do you get “kits” to air ride the cab? Or do you just piece it together?
    M923A2 camo
    M931A2 camo
    M105A2 sold
    M1101 green
    Two M1082
    S-280 shelter
  8. The Following User Says Thank You to Buffalobwana For This Useful Post:
    Csm Davis (10-07-2019)
  9. #18
    Join Date
    Sep 2009
    Posts
    3,988
    1,964
    Default
    Quote Originally Posted by Buffalobwana View Post
    I have looked at lots of over the road trucks and I believe that we can just graft the cab rear mounts and bags and shocks on to the rear of our cabs, but I don't know if the hood to cowl mating flange is going to need attention. I originally was going to be 4 dooring my tractor and it would have much less movement at the front than our day cabs will.
    Jeff Davis
    (601)264-3453
    M928A2
    M927A1 USMC ISO BED
    M927
    M816/936 Half Breed
    M1028/31 Combat Vet
    M1028 Phoenix
    M1010
    2-M1008's
    4-M1009's
    M295a1
    MEP-002A
    2-MEP-003A
    MEP-006
    M101A2/3
    M1101
    M116A2
    M116A3/tool trailer
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
