Results 1 to 6 of 6
Thread: Wtb ccc m915
  1. #1
    I'm the dude, man! Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default Wtb ccc m915
    Looking for a CCC built M915. These trucks had the CAT 16 speed behind the BCI and not the allison like the A1 models.
    Wouldn't mind a cheap 915A1 but sourcing the other parts needed is costly.
    Thanks.
    2008 F-250 6.4L Powerstroke
    1979 AM General M920
    1984 AM General M915A1 (Big Cam III, HT3B Turbo, Brushless 24v Alternator with equalizer, A/C, Rear 20,000lb winch. 11R24 rear tires and 395s up front.)
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  2. #2
    Corporal
    Join Date
    Mar 2008
    virginia
    Posts
    Thanks
    Default
    I'll be on the lookout man.
  3. #3
    4 Star General snowtrac nome's Avatar
    Join Date
    Nov 2016
    western alaska
    Posts
    1,566
    Thanks
    Default
    a lot of the 915's wer changed over to the a-1 model and had Allisons added. I drove an up armored version in Iraq and was quite impressed. You have to remember that because the auto trans makes its shift under turbo boost, not as much power is lost on a shift, unlike the manual transmission, which is why they don't need as many gears to do the same work. The big draw back with the auto is not having a double overdrive but a brownie could fix that to.
  4. #4
    4 Star General NDT's Avatar
    Join Date
    Dec 2008
    Camp Wood/LC, TX
    MVPA
    4954
    Posts
    7,437
    Thanks
    2,171
    Default
    Actually most all 915A0s got made into M915A4s with Freightliner glider kits.
  5. #5
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default
    Quote Originally Posted by snowtrac nome View Post
    The cat 7155 is not a double overdrive unit. Single .83. The cat is also 93 percent efficient on power output. I prefer the cat to the allison honestly. My 923 with the BCIII and 16spd will walk on a 915A1 even loaded. The empty conex load test ive done with my truck. A 916 and a 915a1 yielded my 923 maintaining 56 to the top. 916 with 7155 doing 48 at its slowest point and the 915a1 doing 44.
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  6. #6
    Join Date
    Nov 2016
    western alaska
    Posts
    1,566
    Thanks
    Default
    I to prefer the cat transmission and it has its advantages on the highway but if your like me out here on the dirt or off road most of the time an automatic wouldn't be a deal breaker for me, especially if the truck was in nice condition.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
