Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Deuce starting problem and solution (in this case anyway)
  1. #11
    Colonel
    Join Date
    Mar 2010
    Reydon, OK
    Posts
    369
    Thanks
    602
    Default
    First time I have seen anything like these terminals and I will not be in the market for any! I would like to ad battery cables need high quality shrink wrap installed at every terminal to seal the connection between the cable and terminal.
    1986 M1031 with Pro Fab bale bed
    1986 M1031 Contact Maintenance with gen. & air
    1986 M1031 Contact Maintenance empty box truck
    1986 M1009
    1986 M1009
    1983 M915A1 rebuilt in 2010, NICE
    If all else fails follow directions!
  2. The Following User Says Thank You to royalflush55 For This Useful Post:
    Sparkyz911 (10-13-2019)
  3. #12
    Colonel winfred's Avatar
    Join Date
    Mar 2016
    port allen la
    Posts
    346
    Thanks
    39
    Default
    grease = oxygen barrier to keep corrosion at bay, it doesn't do anything for conductivity
  4. The Following User Says Thank You to winfred For This Useful Post:
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
