Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: M818 Turbo Addition
  1. #21
    Sergeant Major Lonnie's Avatar
    Join Date
    Oct 2013
    Pittsburgh, PA
    Posts
    170
    Thanks
    Default
    Yes, but unfortunately it is almost impossible to see with the turbo & exhaust in place.
    The turbo outlet points straight down, then a 90 deg silicone coupler facing the rear,
    a 3.5" tube to a 90 deg coupler between cab & belle housing,
    to a 45 deg coupler on top of belle housing, which I could not get a picture of,
    then to a 90 deg coupler transitioning to a 4" at the dr. side.
    From there a 4" tube to a 90 deg transition at the 5" intake manifold.
    All the couplers over the belle housing were connected with small pieces of tubing approx 4-5 " long.
    It is a very tight fit back there but it clears nicely & allowed me to have room for Jakes on top of the engine.
    1972 AM General, Turbocharged M818 w/ Deuce Bed & 16.00's
  2. The Following 3 Users Say Thank You to Lonnie For This Useful Post:
    77 AMG (10-12-2019), silverstate55 (10-08-2019), US6x4 (10-08-2019)
  3. #22
    Colonel US6x4's Avatar
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    335
    Thanks
    29
    Default
    I like how simple the entry into the intake is with that routing. I too am eventually going to run a turbo with jakes so this routing is on my mind lately.
  4. #23
    Join Date
    Oct 2013
    Pittsburgh, PA
    Posts
    170
    Thanks
    Default
    It was a rather simple install.
    I've built a lot of custom turbo/supercharger tubing for cars... this was easy compared to fitting 3.5" pressure tubing & a 4" intake in a Camaro.
    Be sure to get aluminized steel or aluminum tubing so it doesn't rust on the inside.
  5. The Following 2 Users Say Thank You to Lonnie For This Useful Post:
    77 AMG (10-12-2019), silverstate55 (10-09-2019)
  6. #24
    Join Date
    May 2011
    Wenatchee, WA
    Posts
    335
    Thanks
    29
    Default
    Do you have to roll a bead on the pipe ends or are the hoses just clamped over smooth pipe?
  7. #25
    4 Star General Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,364
    Thanks
    107
    Default
    Quote Originally Posted by US6x4 View Post
    Do you have to roll a bead on the pipe ends or is are the hoses just clamped over smooth pipe?
    You have to have a bead otherwise they will blow off. Use spring loaded t bolt clamps only
    2008 F-250 6.4L Powerstroke
    1979 AM General M920
    1984 AM General M915A1
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  8. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
  9. #26
    Join Date
    Oct 2013
    Pittsburgh, PA
    Posts
    170
    Thanks
    Default
    On oval pipe, I always use a bead, but I have had good luck with regular t-bolt clamps on just smooth pipes.
    You can carefully flare the end by using a small crescent wrench tweaking the last 1/4" of pipe out slightly. It does not take much & you don't want to see a lump in the hose... At the low boost we are running on these trucks, it isn't typically a problem.
  10. The Following User Says Thank You to Lonnie For This Useful Post:
  11. #27
    Join Date
    Oct 2013
    Pittsburgh, PA
    Posts
    170
    Thanks
    Default
    Started the Jake install today.
    Before Paint...
    Painted & Installed
    It went pretty well....
    Here is a link to the Jake install manual:
    https://parts.jacobsvehiclesystems.c...0E-and-25B.pdf
    It tells you how to install, set clearances etc.
    I swapped my parts without removing the rocker box. This kept me from breaking any gaskets etc.
    It is rather easy:
    1. Replace 1 rocker box bolt at a time with a stud & nut, then torque to specs & repeat 11 more times.
    2. Line up the timing marks as you would to set the valves.
    3. Remove the adjuster screw from the exhaust rocker & pivot the rocker out of the way in order to change the exhaust cross head.
    4. Replace & adjust cross head for clearance.
    5. Replace adjuster & adjust the exhaust valve clearance.
    6. Unscrew the injector adjuster & replace it with the special hex adjuster provided with the Jake Brake.
    7. Adjust the injector.
    8. Finally check and adjust the intake valve clearance.
    9. Move to the next cylinder...
    My biggest issue was the injector adjustment. Having never done this before, I was paranoid & wanted to be sure my torque wrench was accurate. I carefully checked the existing preload to see where they were so I was sure I was doing it properly.
    They were all fortunately within spec & returned to the specified torque.
    I then installed the Jakes & torqued them down.
    Loosen the Jake exhaust set screws & reset the clearance to .018" following the same cylinder rotation sequence as you used to set the valves.
    Before putting the rocker covers on, I started the engine & bled the solenoids.
    Once the got the air out, you could push a solenoid plunger & hear the engine sputter.
    Now for the wiring...
  12. The Following 3 Users Say Thank You to Lonnie For This Useful Post:
    77 AMG (10-13-2019), silverstate55 (10-13-2019), US6x4 (10-12-2019)
  13. #28
    4 Star General 74M35A2's Avatar
    Join Date
    Oct 2013
    Livonia, MI
    Posts
    3,896
    Thanks
    440
    Default
    Nice work, clean install. Thanks for posting details and answering questions.
    CFO @ Portacharger
  14. The Following User Says Thank You to 74M35A2 For This Useful Post:
    silverstate55 (10-14-2019)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
